DSTROY Posted October 22, 2008 Share Posted October 22, 2008 ok, no probs Im thinking of getting cam gears now as well, might as well get everything put on at the same time so i only have to get it tuned once. Link to comment https://www.sau.com.au/forums/topic/225222-pgasa-interclub-dyno-day-2-18th-of-october/page/7/#findComment-4212370 Share on other sites More sharing options...
Krishy Posted October 23, 2008 Share Posted October 23, 2008 cool cheers chad once you get the link mate let us know Link to comment https://www.sau.com.au/forums/topic/225222-pgasa-interclub-dyno-day-2-18th-of-october/page/7/#findComment-4213168 Share on other sites More sharing options...
SLED Posted October 23, 2008 Share Posted October 23, 2008 Chad the idea of adjustable cam gears is to shift the power and as you can see below, SK only changes the EX gear and retards it approx 4 deg as a starting point. I bought 2 JJR adjustable cam gears from Just Jap and should've only bought one so I have a spare gear if you're interested. The gurus interstate i.e. Duncan etc swear by the JJR gears. Hi Rob, by retarding the exhaust camshaft timing I am aiming for more mid range, but I can get a bit of top end as well. There is also some faster spooling to gained as well. What it achieves is more complete combustion, before the exhaust valves open. Plus you get slightly higher combustion pressure, for more torque. You don't get something for nothing though, it also means you get less overlap, the inlet valve isn't open at the same time as the exhaust valve for as long. This means the incoming inlet charge (air and fuel) doesn't help push the exhaust out. This is why it works well with a bit of extra boost (above standard) as that offsets the shorter "push" time. cheers: On inlet cam timing adjustment? Very little difference, not worth the effort.Cheers gary and check the 2nd page of this thread Re: JJR Cam Gears and this JJR Cam Gears ................AND THIS Link to comment https://www.sau.com.au/forums/topic/225222-pgasa-interclub-dyno-day-2-18th-of-october/page/7/#findComment-4214045 Share on other sites More sharing options...
Madaz Posted October 23, 2008 Share Posted October 23, 2008 ok here is a little tit bit Link to comment https://www.sau.com.au/forums/topic/225222-pgasa-interclub-dyno-day-2-18th-of-october/page/7/#findComment-4214361 Share on other sites More sharing options...
J - Rad Posted October 23, 2008 Share Posted October 23, 2008 LOL! all I see and hear is redline and smoke, thats about it! Awesome work Pete Link to comment https://www.sau.com.au/forums/topic/225222-pgasa-interclub-dyno-day-2-18th-of-october/page/7/#findComment-4214371 Share on other sites More sharing options...
SLED Posted October 23, 2008 Share Posted October 23, 2008 haha good work Steve, now show a clean run please buggered if I know how that run made 299KW Link to comment https://www.sau.com.au/forums/topic/225222-pgasa-interclub-dyno-day-2-18th-of-october/page/7/#findComment-4214400 Share on other sites More sharing options...
J - Rad Posted October 23, 2008 Share Posted October 23, 2008 I'd love 299kw! Can I borrow some? Link to comment https://www.sau.com.au/forums/topic/225222-pgasa-interclub-dyno-day-2-18th-of-october/page/7/#findComment-4214412 Share on other sites More sharing options...
SLED Posted October 23, 2008 Share Posted October 23, 2008 its done a 335KW as is with the same rich tune so with an adjustable EX cam gear and a decent tune it should pull 350KW with the current mods Link to comment https://www.sau.com.au/forums/topic/225222-pgasa-interclub-dyno-day-2-18th-of-october/page/7/#findComment-4214435 Share on other sites More sharing options...
Madaz Posted October 23, 2008 Share Posted October 23, 2008 i think that was you good run 302 rwkw Link to comment https://www.sau.com.au/forums/topic/225222-pgasa-interclub-dyno-day-2-18th-of-october/page/7/#findComment-4214485 Share on other sites More sharing options...
SLED Posted October 23, 2008 Share Posted October 23, 2008 lol.......I'd hardly call bus exhaust fumes a good run Link to comment https://www.sau.com.au/forums/topic/225222-pgasa-interclub-dyno-day-2-18th-of-october/page/7/#findComment-4214515 Share on other sites More sharing options...
Madaz Posted October 23, 2008 Share Posted October 23, 2008 sorry my bad i dont seem to have the 302 only the 299 wasn't much difference Link to comment https://www.sau.com.au/forums/topic/225222-pgasa-interclub-dyno-day-2-18th-of-october/page/7/#findComment-4214540 Share on other sites More sharing options...
Krishy Posted October 24, 2008 Share Posted October 24, 2008 sorry my bad i dont seem to have the 302 only the 299 wasn't much difference the 302 run was a clean run no bus smoke on that run Link to comment https://www.sau.com.au/forums/topic/225222-pgasa-interclub-dyno-day-2-18th-of-october/page/7/#findComment-4215421 Share on other sites More sharing options...
Damo_R34 Posted October 24, 2008 Share Posted October 24, 2008 oh well, 3kw is as much power as a sneeze, not much difference Link to comment https://www.sau.com.au/forums/topic/225222-pgasa-interclub-dyno-day-2-18th-of-october/page/7/#findComment-4215434 Share on other sites More sharing options...
Krishy Posted October 24, 2008 Share Posted October 24, 2008 oh well, 3kw is as much power as a sneeze, not much difference its 3 kw that would push you past 200rwkw mark wont it damo plus it was a much much cleaner run Link to comment https://www.sau.com.au/forums/topic/225222-pgasa-interclub-dyno-day-2-18th-of-october/page/7/#findComment-4215456 Share on other sites More sharing options...
DSTROY Posted October 24, 2008 Share Posted October 24, 2008 Hey guys, my mate try'd to upload that video onto his computer but he couldn't get it to work, maybe cos the camera is pretty old i think the extra 3 kw was made be the water that was sprayed onto the intercooler on the last run. Link to comment https://www.sau.com.au/forums/topic/225222-pgasa-interclub-dyno-day-2-18th-of-october/page/7/#findComment-4215891 Share on other sites More sharing options...
Damo_R34 Posted October 24, 2008 Share Posted October 24, 2008 the JustJap.com website says they are out of Single RB JJR cam gears Link to comment https://www.sau.com.au/forums/topic/225222-pgasa-interclub-dyno-day-2-18th-of-october/page/7/#findComment-4216129 Share on other sites More sharing options...
DSTROY Posted October 24, 2008 Share Posted October 24, 2008 I bought 2 JJR adjustable cam gears from Just Jap and should've only bought one so I have a spare gear if you're interested. Awesome, let me know what you want for it. Link to comment https://www.sau.com.au/forums/topic/225222-pgasa-interclub-dyno-day-2-18th-of-october/page/7/#findComment-4216118 Share on other sites More sharing options...
SLED Posted October 24, 2008 Share Posted October 24, 2008 and they've still got their old prices listed......I think their next batch will be dearer due o the $AU. Chad it's still sealed in the plastic wrapper, you can have it at the old price (what I paid for it) and save on freight too Link to comment https://www.sau.com.au/forums/topic/225222-pgasa-interclub-dyno-day-2-18th-of-october/page/7/#findComment-4216345 Share on other sites More sharing options...
