  • Replies 137
Posted Images
Chad the idea of adjustable cam gears is to shift the power and as you can see below, SK only changes the EX gear and retards it approx 4 deg as a starting point.
I bought 2 JJR adjustable cam gears from Just Jap and should've only bought one so I have a spare gear if you're interested. The gurus interstate i.e. Duncan etc swear by the JJR gears.
Hi Rob, by retarding the exhaust camshaft timing I am aiming for more mid range, but I can get a bit of top end as well. There is also some faster spooling to gained as well. What it achieves is more complete combustion, before the exhaust valves open. Plus you get slightly higher combustion pressure, for more torque.
You don't get something for nothing though, it also means you get less overlap, the inlet valve isn't open at the same time as the exhaust valve for as long. This means the incoming inlet charge (air and fuel) doesn't help push the exhaust out. This is why it works well with a bit of extra boost (above standard) as that offsets the shorter "push" time.
cheers:
On inlet cam timing adjustment? Very little difference, not worth the effort.
Cheers
gary
and check the 2nd page of this thread Re: JJR Cam Gears
and this JJR Cam Gears
................AND THIS
oh well, 3kw is as much power as a sneeze, not much difference :D
its 3 kw that would push you past 200rwkw mark wont it damo
plus it was a much much cleaner run
Hey guys, my mate try'd to upload that video onto his computer but he couldn't get it to work, maybe cos the camera is pretty old :D
i think the extra 3 kw was made be the water that was sprayed onto the intercooler on the last run.
Awesome, let me know what you want for it.
and they've still got their old prices listed......I think their next batch will be dearer due o the $AU.
Chad it's still sealed in the plastic wrapper, you can have it at the old price (what I paid for it) and save on freight too
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
