Hi all
Im only new to this as i just bought an r 33 gtst 4 door. But i put a set of blade rims from bob jane t-marts on and i ended up with a massive chunk taken out of the left front wheel. Tottaly stuffed had to buy a whole new rim cost 395 dollars real annoyed. Anyway when i drive it sounds like a deep whining noise around 50 to 60 ks maybe the axel is bent or just wondering if anyone would know about this. its only done 60,000 ks so nothing wrong with the engine. any help would be great cheers.
scottyboy
https://www.sau.com.au/forums/topic/225253-just-new/
dont actually know what happened but its the front left and i dont think that it is the diff because it is only when i get to a little bit of a higher speed that the noise occurs. i might just have to get it checked out
https://www.sau.com.au/forums/topic/225253-just-new/#findComment-3969178
Sounds to me like you hit soimething which caused the rim damage.
The noise sounds like the impact has "bruised" the bearing. The noise will get worse, and eventually your wheel will probably fall off....this will damage the rim again and you will need to buy a 6th one :)
https://www.sau.com.au/forums/topic/225253-just-new/#findComment-3971907
i sort of agree with bard get your alignment bearings and other steering style stuff checked (cheaper than a new rim)
oh and its ok if you dont tell us about that curb you jumped ( i neglect to mention my motorsports "incidents" all the time)
https://www.sau.com.au/forums/topic/225253-just-new/#findComment-3974448
Wheel bearing gone? Or on its way out?
If this is the case, eventually the wheel will sieze up and not rotate any more.
Pretty easy to replace, pull of wheel, take of the brake rotor, and replace them.
https://www.sau.com.au/forums/topic/225253-just-new/#findComment-3975569
cheers car is going in for a service tomorrow so it will be fixed. i didnt say that i didnt hit a curb i just don't remember doing it. anyway was told by my mechanic the same thanks for the reply
cheers Scottyboy
ps i wasn't drunk as i don't drink. :P
https://www.sau.com.au/forums/topic/225253-just-new/#findComment-3982912
hey was just teasin bout the curb hope it all works out well
i had problems with a vibration at 80-100 kph for ages that i couldnt find (mechanics/ wheel blokes/ suspension blokes either) finally went away when i replaced some stearing bushes when i installed the swaybars go figure
and lets not even go into motorsport "incidents"
luck aye
GWP
https://www.sau.com.au/forums/topic/225253-just-new/#findComment-3987573
na its all sweet now the mechanics that i go to found it. it was just wheel Bearing, but they said that they called nissan in osbourne park and that it was going to cost me 400 dollars because i had to order the hub as well. Anyway they did some research for me and just found the bearing s under 100 dollars so its all good now run s like a charm cheers guys,
cheers scottyboy
https://www.sau.com.au/forums/topic/225253-just-new/#findComment-3989863
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
