Over the last few days I've been having a good fiddle with my suspension setup trying to get the car lower and balanced.
Basically what I've got are standard springs and Bilstein adjustable shocks. The spring seats were on the higher of the two circlip grooves, so I took the shocks out and moved the circlip down to lower the car that little bit. For my first time, it was a seriously annoying process. Eventually I got it all done.
I noticed then that the driver's side was sitting lower than the passenger side. I know that this sag does happen over the life of a car (and mine is 16 years old) so I thought what I'd do is switch the sides over to get it closer to balanced when my body weight is on the driver's side.
So I pulled all the shocks out, and made double triple sure that they were matching heights, and swapped them over.
Anyway, finished that and measured it up again and the driver's side is still sitting lower than the passenger side by about 10-15mm or so at the front (rears are almost identical).
What else can cause this sag? Worn bushes? Something else? Would love any help. Ideally I'd love to get the passenger side sitting down as low as the driver's, but if it's something that's worn then obviously that won't work.
https://www.sau.com.au/forums/topic/225279-drivers-side-sagging/
I had the same problem mate. My drivers side was 10mm lower than the PS, so i just compensated by raising and lowering the circlips on the shocks. It now sits even.
I was told that cars of this age flex, sag, twist etc so its not that uncommon. Its unusual, however, that your rears are the same height and its only the front thats sagging. I actually had to work diagonally by raising the DS rear 1 groove and lowering the PS front 1 groove to get my desired height.
Shaun.
^^^ obviously :D
The difference is generally 3-4mm, park it on a road it'll look level, park on a flat peice of concrete it won't measure level.
Track springs are not the same...tracks have little to no camber, sports springs...some brands are some aren't.
Road springs.....
Edited by madbung
Left and right springs when new are generally a different height..it's to allow for the amount of camber built into roads, so the car can track correctly.
I've never heard of this before, i dont think thats true at all.
What car do you know came out with different driver+passenger side springs?
Does it sound like something I just made up? Or do you think it may well be something you have never heard about before?
Go search your vast bank of knowledge again, maybe you just missed it.
Answer to the question...all production cars have a bias, whether it's done via springs or other methods (it's so the car can track correctly on cambered roads-thats all roads) unless they have after market suspension.
I really am getting pissed dispensing sound advice, then having to explain it to the third degree.
I think I'll quit..
To the guy with the problem, springs will wear on one side of the car more than the other because it's under more load due to the camber built into roads. So if it's only a couple of mm it's normal.
Edited by madbung
I'm not questioning your theory, I just want to know what's causing it, as it isn't springs in my case. I explained in my first post that I have swapped the shocks and springs over but the drivers side is still sagging lower than the passenger side. My question is, what causes this as it cannot be the springs themselves.
Edited by HuH
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
