Hey just puttin an EOI atm seeing whats out there atm NOW FOR SALE!!!! NOW TAKING GENUINE OFFERS
located: Brisbane
price: EOI really atm ...but to keep mods happy around 12-13k NEGOTIABLE
extra info: vehicle does not have rego and needs mod plates, IT IS COMPLIED, and it CAN be plated and regoed though
will also take things off for cheaper sale.
OPEN TO SWAPS FOR CEFIROS LAURELS and R32 4 DOOR
contact: 0411023878 or PM
Engine:
1988 Nissan Silvia - sunroof - HUD
SR20DET VCT Blacktop out of s14 (series 1)
Modified CA18/S14 engine harness
Chipped and tuned ECU
Cometic 1.5mm head gasket
Just Jap front mount intercooler with modified hybrid piping
20 thou oversized forged pistons
ACL big end main and thrust forged bearings
Greddy Type R bov
Custom thermo fan setup (AUIII Falcon thermos)
Just Jap stainless steel exhaust manifold
GT2860rs disco potato w/ .64 exhaust housing
2.5" stainless steel split dump pipe
2.5" stainless steel front pipe
Stainless steel de-cat pipe
3" straight thru pipe to flange with bolt on cannon
Boost tee
K&N pod filter
Walbro Fuel Pump
Engine Dampener
NISMO Fuel pressure regulator
Transmisson:
S14 gearbox
Short shifter
NPC heavy duty 5 puck brass button clutch with a HKS 1200kg pressure plate
Solid gearbox mount
Suspension and Handling:
Solid steering shaft spacer
R180 locked diff
5 stud conversion
F - s14 LCA, S14 stub axle, s14 hub, r32 brake calipers (4 pot) and rotors
R - s15 hubs, s15 rotors, s13 caliper
Adjustable castor rods
S13 steering rack w/ R32 skyline tie rods and tie rod ends with 10mm spacers in rack
KTS Hicas lock bar
Tein HA coilovers with adjustable camber tops
Rear Strut Brace
Interior:
Safety 21 - Full 7 point rollcage bolt in
DRiFT steering wheel
Dildo gearknob
Jap extension mirror
Drift button
FET Turbo timer
Fibreglass door cards
Custom switch panel setup
Killswitch
Fully stripped interior and sound deadening
Interior painted silver
Autogage 52mm Boost gauge
Autogage 52mm Oil Temp gauge
Autogage 52mm Water Temp gauge
Fire extinguisher
Fully sick neons
Exterior:
Genuine silvia square headlights
Xenon headlight bulbs
Black corner lamps
BN side skirts
BN front bar
Vertex rear bar
Flared and pumped rear guards
Clear taillights
F: HP Racing wheels 18x9 tyres: Falken Ziex 235/40/18
R: HP Racing wheels 18x10 tyres: Falken Ziex 255/35/18
25mm bolt on wheel spacers on rear
8mm floater spacers on front
Paint: -Gloss white paint
-Black roof with heavy gold sparkle
show me what you got!!!
thanks
-josh
https://www.sau.com.au/forums/topic/225281-built-sr20-blacktop-s13/
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
