Group Buy: 60mm Ams Gauges + Shadow Gauges (new)
This Group Buy will ends on 20th July 2008 (Sunday)
My trader feedback: http://www.skylinesaustralia.com/forums/in...=35717&la=0
I have got a mate working in www.espadaperformance.com. And thus, I have gotten you guys a very good price on the gauges. Therefore, I post it up here, hoping to share this great deals with you guys.
the product offer is AMS 60mm Gauges. You guys can check what's the RRP of these gauges from the website.
This group buy will just be series 2 gauges as series 1 gauges have been cleared.
Series 2 will cost $60.
Gauge Cover will cost $2.
Water and Oil adaptor will cost $20.
Fitting mount will be included in the box when you buy a gauge.
Payment preferred: Bank Transfer.
Delivery & Conditions of Delivery: courier interstate only.
Product features:
2.5" STEPPER MOTOR GAUGE
• Provides smooth operation • Very exact
• High precision & quick response • Bright LED illumination
• Precise electrical sensor • Does not require any Control Unit for use
Series 2:
Stepping motor provides smooth operation
Ignition ON initiates self-luminescence gauge
Lightning-like Opening / Closing mode
Example of Opening
Adjustable warning setting
Self-diagnostics function monitors both sensor disconnection and short-circuiting during startup
a) Sensor disconnection check
This function reports any improper connections, broken or disconnected sensor or sensor
wire. The pointer will wave between 250 and 260 degrees.
b) Short-circuiting check
This function indicates any short circuit on the sensor or sensor wire.
The pointer will wave between 10 and 20 degrees.
Using High-brightness LEDs Illumination
Illumination color can be chosen from white, amber ,red, green and blue
Product List:
TACHO 0-10,000RPM
BOOST PRESSURE BAR
WATER TEMP 50-120℃
OIL TEMP 60-150℃
OIL PRESSURE 0-7kg/cm2
VACUUM 0–30 in.hg
VOLTAGE 8-16VOLT
INTAKE.TEMP 20-120℃
A/F RATIO LEAN-STOICH-RICH
Please note that the A/F Ratio gauge comes only in Silver watchcase.
Note: You guys can choose between silver or black watchcase for the series 2 gauges (except A/F Ratio, which only comes in Silver watchcase).
NOTE:
For those who are interested, please let me know:
- what gauge you're interested in
- your color choice for series 2 (Black or White watchcase)
- Your LED light choice
Espadaperformance has start selling a higher quality range of gauges brand called "Shadow"
I just post it together to see anyone is interested in this range.
You can go to the website to read more on this gauge range.
there are 3 broad models:
1st Picture above is SMOKE FACE WHITE LIGHT
2nd Picture above is CLEAR FACE WHITE LIGHT (White)
3rd Picture above is CLEAR FACE WHITE LIGHT (Black)
Picture 1 and Picture 3 has a choice between 52mm or 60mm whereas Picture 2 comes only in 60mm
I was shocked to see that the gauges is only 3cm thick!!!!!
Anyway, you have a choice of a gauge cup holder or the gauge ring holder.
A picture of the gauge can be seen here:
Product List:
- Water Temp
- Oil Temp
- Oil Press
- Turbo
- Voltage
- Intake Manifold Press
Please note that the Exhaust Temp gauge are currently out of stock.
The best price I could get for this gauges is $150 each
Shadow Water Adaptor will cost $30 (choice of 28mm, 30mm, 32mm, 34mm, 36mm, 38mm, 40mm)
Shadow Oil Temp Adaptor will cost $30
Both Adaptors have a choice of colors - Blue, Silver, Grey
You guys are given a choice between these 2 brands.
If you're interested in this brand,
please tell me:
- what gauge you want
- your choice out of the 3 models - Smoke, Clear Black or Clear White
- tell me your preferred gauge size - 52mm or 60mm (for the 2 models)
- if you're also buying the adaptors, choice of dimension for water adaptor is needed and your color choice.
- tell me you prefer a cup holder or the ring holder.
Will start taking orders from now till 20th July 2008.
not missing out on this one lol
oka i would like:
1x Series 2 Boost guage, Black watch case and White LEDs (if you can get the boost guage in PSI that would be awsome)
1x Series 2 Oil Temp Guage, Black Watch case and White LEDs
1x Oil Temp adaptor thingy
cheers
oka i would like:
cheers
Sure thing mate. :D
but i'm sad to tell you that boost gauge comes only in bar. are you still interested?
Cheers.
Sure thing mate. :D
Cheers.
ahh k yer thats cool man still intereested
cheers
hi mate,
- can u get the boost gauge that reading in psi ?
- shadow gauges in 52mm are the same $$ as 60mm ? can u get any other colour light ?
cheers
Ford
Shadow gauges: 52mm are the same as 60mm.
there are only 3 variations for shadow gauges. so sorry about that. but there are good gauges, from the desriptions and the information.
the boost AMS boost gauge; it is hard to get PSI reading. because they have no more stock.
if you're really interested let me know, i'll see what i can do and enquire for you and get back to you.
im assuming it doesnt have a peak warning function ?or does it ?
there are 3 cm thick only. haha...
both gauges have peak warning function.
but shadow ones allow you to set it.
take a look at the website for more info. :)
Hi mate,
I'm very keen on the AMS boost gauge in PSI
cheers
take a look at the website for more info. :P
I did
and it says
Features
• Stepping motor provides smooth operation
• Ignition ON initiates self-luminescence gauge
• Lightning-like Opening/Closing mode
• Adjustable warning setting
• Self-diagnostics function monitors both sensor disconnection and short-circuiting during startup.
• Using High-brightness LEDs illumination and color can be chosen from whiter, amber, red,
green and blue.
so are these different ? or can the warning setting be adjusted?
I did
and it says
Features
green and blue.
Hey mate,
they are adjustable. you have to read the manual after you buy them and you'll know how to do it. :blink:
Cheers. :)
hey mate u reckon u could get a pick of the cup holder and the ring holder..just wanna see which 1 id prefer
cheers
hey mate,
the choice for cup holder and ring holder is for shadow gauges only.
AMS gauges comes in ring holders only.
Cheers. :D
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
    • You have to continuously fill it to avoid dry running. Personally the transmissions I've serviced have never been bad enough to justify doing this because it is definitely a pretty complicated and somewhat risky procedure compared to simply draining the pan, measuring what came out, then refilling with the exact same amount.
