This weekend Eastern Creek Raceway will hold the fourth round of the Drift Australia series.
I will be there all weekend with the Federal Tyres crew, we will have a big tent and display with give aways and goodies for sale, I hope that there will be plenty of SAU'ers coming to watch the action!
Make sure that you come to the Federal tent say G'day, have a close look at Nathan Weissel's awesome Federal Tyres R32 Skyline drift car and I'll shout you some freebies!
Hope to see many of you there! :O
Cheers
Mick
https://www.sau.com.au/forums/topic/225635-drift-australia-round-4/
Great day today, perfect weather. Shame about Nates troubles re: stripping driveshaft spline on saturday, and having to replace the turbo today due to (we think) oil starvation :cool:
You have to start young if you wanna be the next generation of Drift Queen
Nathans daughter making broom-broom noises in daddies car :)
Some ppl come more prepared than others to motorsport events...
lol
1st Leighton Fine-Blue Nissan 180SX, 2nd Luke Fink-Green Nissan Silvia, 3rd Beau Yates-White Toyota AE86 Sprinter
So yea, was there all day Sunday. Had loads of fun :) Was in the pits, watched some stunting :banana: dropped by at the federal garage...but nobody there :D
Saw heaps of skylines, almost looked like a show 'n' shine where everyone parked :D
Ill get some pics of my mate shortly, who took around 600....... ;)
I have to appologise to everyone who came past the Federal tent when I wasnt there, it turned out that we had a major shortage of tyres for some of our sponsored drivers so we spent most of Saturday chasing them down, then on Sunday we had to go to our Taren Point warehouse and pick them up (fairly long drive from Eastern Creek to Taren Point) but we ended up getting the tyres in time and everything went to plan. ;)
It was a very busy weekend for us but we still had a blast!
Thanks to all those who came to watch the action. :D
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
