My electric mirror adjustment isnt working on the right side. After some investigation i found there is a damaged wire going from the switch to the mirror motor. The mirror plug has 5 wires. The one i found to be damaged is the Purple wire with a Black trace. Has anyone ever had a similar problem? Is it more likely to be the plug in the door jam. Also is there an easier way to access the plug/loom in the foot well/door jam? It is incredibly difficult to get to.
https://www.sau.com.au/forums/topic/22576-electric-mirrors/
i never had a skyline mirror apart but electric mirrors have 2 small electric motors one for in -out other for up-down .
u take the mirror off the car and take it apart then u'll see them they are very small . sometimes they have bad connection , check that spray some wd40 and test the motors on a 12 volt battery if they work then look for damaged wires .
https://www.sau.com.au/forums/topic/22576-electric-mirrors/#findComment-486101
Originally posted by chicane
My Drivers side mirror doesn't work for the adjustment - it folds in and out OK though - Checked switch on dash looks OK I think they stuffed something when they changed it from convex to flat at compliance :|
any tips for the mirror removal
Mine's still convex. :uh-huh:
https://www.sau.com.au/forums/topic/22576-electric-mirrors/#findComment-486728
its not hard to remove look under the mirror it should have 2-3 bolts undo them and its out but u may have to undo the bolts inside the car as well not sure but take the little trim off on the inside and see there should be 2- 3 there as well .
https://www.sau.com.au/forums/topic/22576-electric-mirrors/#findComment-487276
You have to take the whole door trim off to get to the plug, that isnt difficult though.
https://www.sau.com.au/forums/topic/22576-electric-mirrors/#findComment-487935
  • 11 months later...
has any of you guys solved this problem since last year?
My driver side had problem now... the up/down left/right adjustment is fine, but the mirror only wanna fold in with a click click and slight delay compared to the left one, and once it folds in it doesn't want to fold out anymore..
from those wire colours above, has anyone figure out which wire colour for which function?
https://www.sau.com.au/forums/topic/22576-electric-mirrors/#findComment-972324
  • 4 weeks later...
the 2 black wires on the mirror make it fold in and out, it has its own plug that goes behind the door trim. There are another 5 wires that do something with the mirror, theres blue, purple, yellow, pink and orange. I have no idea what wires for what.
My stock mirrors both sides only move in 2 directions - down and left, it should go up down left and right.
I took the mirror off and sprayed the motor with WD40 stuff and it made no diff at all.
I wanted to hook up a new set of aftermarket mirrors but they only have 3 wires, so I hooked them up to the matching colour and the mirrors only moved up and down, I decided to join another wire up and see if it made a diff, it just blew a fuse.
Any idea on both my problems?????
https://www.sau.com.au/forums/topic/22576-electric-mirrors/#findComment-994963
ok i had exactly the same problem as you drivers side up down left right is fine just click click click and wont move in or out, im an electronics technician so i pulled it apart all the voltages were fine so its not an electrical prob i rang up just jap in syd and they the first thing to go on skylines is always drivers side electric window and electric mirrors. i couldnt find anything wrong so i just bought a new mirror and it goes fine. but if you dont care about the in out thing just leave it out.
https://www.sau.com.au/forums/topic/22576-electric-mirrors/#findComment-995425
Hey
Dont really know, only noticed it when I tryed to install aftermarket mirrors which I didnt end up doing as they didnt fit :)
When the mirrors are out the move only 2 directions, when I fold them in the move the other 2 directions but still only move in 2 directions. Also when they are out when I try to move the mirrors sometimes they move ok but sometimes the click when they are trying to move.
When you said it might be the switch, did you mean the whole door bit or just the mirror control that you pop out by itself???
https://www.sau.com.au/forums/topic/22576-electric-mirrors/#findComment-998570
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
