Hey All,
Just wondering if anyone had contacts where we can buy alloy cores without tanks from, preferably in sydney area.
Large cores required either std top to bottom - or side tanked cores would be better to create a new twin pass radiator if i can with remote tank.
i'll be making a new radiator for an R33 Gtst and im hoping to these cores arent too expensive.
i'll also be looking at the vt commie v6 cores as they are side tanks and pretty thick std from memory - will have to confirm core sizes soon.
https://www.sau.com.au/forums/topic/225799-alloy-radiator-cores/
Hey All,
i was looking at this ages ago, i think from memory for a decent sized good quality core it was about $400ish for an ally one.. after factoring in the cost of the neck, etc, blah, i'd rather pay someone like pwr $750 and save me the f**k around... maybe the place i got the price from was rippin me but..
thats definately possible.
and if anyony knows if you can join 2 thinner alloy cores together without having major flow issues that could be an option also.
Its not worth the effort mate, your better off tracking down a radiator out of a AU Ford onwards and make your own tanks :(
Its not worth the effort mate, your better off tracking down a radiator out of a AU Ford onwards and make your own tanks :blush:
yep i'll have to look into the space that is available and spend some time at a natrad store trying to get one that will work. i think the commodore one we used in a mates sprinter for this was about $110
only just saw this.. having trouble remembering the brand name of the cores they use to order in when i was working at the radiator shop.. either way if you messure up wat size core you want you can get it custom ordered and usually isnt to exxy all of the companys that make cores will do it..
as long as it works out cheaper than a Just jap cooling pro i'll be happy :)
not something i HAVE to get done, but i want to make one - radiator filler necks arent price listed from motorsport connections so i'll find that price out tomorrow hopefully.
i'll be running a remote filler so there is no cap on the radiator itself (like a falcon with it on a remote reserve tank) so i can weld up a new canister well above the top of the motor for bleeding.
would like to have multiple returns similar to how the GTRs water outlets are across the TB's, but i'll need to look into the water routing in the rb25 heads.
  • 1 year later...
  • 2 months later...
Yeah best bet is PWR or Natrad, Pwr is the better choice from memory it will sting you bout $400ish.
If you plan on making it yourself make up some cover plate to protect the fins when welding and some blanks to test the rad, I normally pressurize them to about 20 psi then submerge them in water to find any pin holes, just make sure that before you go to weld it up to clean all the flux and solder off of the joints your about to weld.
Try useing scotch brite rolocs ( the brown ones) there not too aggresive and will give you a nice clean joint then wipe it down with acetone and it should come out a treat if you need anymore help drop me a pm I can't tell you how many different rad's I've made too many to mention.
Oh and if your makeing a res tank for it get some spun end caps for the top and bottom you can get alot of different shapes just pick the one you like most and a bit of ali tube and the jobs done! good luck mate
Oh yeah another trick bit is to put your oil cooler into one of the side tanks it look the biz and works a treat too hope that helps.
Almost forgot buy some spun donuts too for your exit pipe its a much tighter rad than any elbow you can get and then you can have it come of in any angle you like and have a few more peice's left over if you want to make up some hard lines to return to the engine.
Edited by The BOP
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
