Hey All,
Just wondering if anyone had contacts where we can buy alloy cores without tanks from, preferably in sydney area.
Large cores required either std top to bottom - or side tanked cores would be better to create a new twin pass radiator if i can with remote tank.
i'll be making a new radiator for an R33 Gtst and im hoping to these cores arent too expensive.
i'll also be looking at the vt commie v6 cores as they are side tanks and pretty thick std from memory - will have to confirm core sizes soon.
https://www.sau.com.au/forums/topic/225799-alloy-radiator-cores/
Hey All,
i was looking at this ages ago, i think from memory for a decent sized good quality core it was about $400ish for an ally one.. after factoring in the cost of the neck, etc, blah, i'd rather pay someone like pwr $750 and save me the f**k around... maybe the place i got the price from was rippin me but..
thats definately possible.
and if anyony knows if you can join 2 thinner alloy cores together without having major flow issues that could be an option also.
Its not worth the effort mate, your better off tracking down a radiator out of a AU Ford onwards and make your own tanks :(
Its not worth the effort mate, your better off tracking down a radiator out of a AU Ford onwards and make your own tanks :blush:
yep i'll have to look into the space that is available and spend some time at a natrad store trying to get one that will work. i think the commodore one we used in a mates sprinter for this was about $110
only just saw this.. having trouble remembering the brand name of the cores they use to order in when i was working at the radiator shop.. either way if you messure up wat size core you want you can get it custom ordered and usually isnt to exxy all of the companys that make cores will do it..
as long as it works out cheaper than a Just jap cooling pro i'll be happy :)
not something i HAVE to get done, but i want to make one - radiator filler necks arent price listed from motorsport connections so i'll find that price out tomorrow hopefully.
i'll be running a remote filler so there is no cap on the radiator itself (like a falcon with it on a remote reserve tank) so i can weld up a new canister well above the top of the motor for bleeding.
would like to have multiple returns similar to how the GTRs water outlets are across the TB's, but i'll need to look into the water routing in the rb25 heads.
  • 1 year later...
  • 2 months later...
Yeah best bet is PWR or Natrad, Pwr is the better choice from memory it will sting you bout $400ish.
If you plan on making it yourself make up some cover plate to protect the fins when welding and some blanks to test the rad, I normally pressurize them to about 20 psi then submerge them in water to find any pin holes, just make sure that before you go to weld it up to clean all the flux and solder off of the joints your about to weld.
Try useing scotch brite rolocs ( the brown ones) there not too aggresive and will give you a nice clean joint then wipe it down with acetone and it should come out a treat if you need anymore help drop me a pm I can't tell you how many different rad's I've made too many to mention.
Oh and if your makeing a res tank for it get some spun end caps for the top and bottom you can get alot of different shapes just pick the one you like most and a bit of ali tube and the jobs done! good luck mate
Oh yeah another trick bit is to put your oil cooler into one of the side tanks it look the biz and works a treat too hope that helps.
Almost forgot buy some spun donuts too for your exit pipe its a much tighter rad than any elbow you can get and then you can have it come of in any angle you like and have a few more peice's left over if you want to make up some hard lines to return to the engine.
Edited by The BOP
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
