Ok so I'm getting really pissed off now, and before I put a fist sized hole through the LCD, I'll see if anyone here can help out.
Its pretty simple really...I've got a ps3, HDMI cable and a Samsung 19" LCD (LA19R71BX: Link to specs)
The PS3 works fine in full HD downstairs on the 46" Samsung M8 LCD, but people are usually watching that TV so I need to get it working up here as well.
Basically I plug the HDMI cable into the LCD, switch on the PS3 and LCD, and hit the 'source' button to get it into HDMI mode, where all I get is a blue screen and the message 'mode not supported'
Considering the TV is HD, has a HD input, I see no reason why it shouldn't work!
Hopefully someone here knows why and can sort it out for me.
Cheers
https://www.sau.com.au/forums/topic/225815-ps3-samsung-19-lcd/
Holy shit... it only has a 8ms refresh rate. I didnt even know they made that anymore
i think it may be that you've set the PS3 to read at a cetain output level on your 46 incher, and now that you've moved down to a possibly smaller output level TV, your not getting the signal. You may have to plug it back into the bigger TV and screw with your settings.
a tech head may be able to explain it better, but im pretty sure thats teh problem
Edited by ctjet
I took it back downstairs the last time I tried to connect it up here...the resolution setting is set to auto so in theory it should really adjust itself to the TV its being connected too...seems pretty stupid if you have to set it up on the other TV everytime you want to move it from one to another.
I don't know much about the PS3 since i don't have one, but that TV says it's HD ready. It just doesn't have a full HD res, which shouldn't matter, it should take the 1080i signals and display it anyway. Doesn't the PS3 do 1080p? Maybe the TV doesn't like that, it wants 1080i?
Screen Size 19"
Resolution 1440 x 900
Dynamic Contrast Ratio 600:1
HD Ready Yes
LCD 100Hz N/A
Try this Dezz.
1) Set the TV to HDMI mode
2) Connect the HDMI wire to TV and PS3
3) Hold the power button for 5 seconds until you hear 2 beeps
switch between the different HDMI channels if u have more than 1.. and look for a picture...
you dont have to disconnect anything in the back of the tv... just make sure the HDMI is the only video output attached to your ps3.
2) The secret video reset
One of the most annoying aspects of the PS3 are its video settings. Take it up to the bedroom portable or round to a friend's house and there's a good chance that you won't be able to see anything on screen because your 'new' TV is running at a different resolution or using a different cable connection. And - because you can't see anything - you can't change it.
Until now. Shut down your PS3 then restart by pressing and holding the power button.This will reset your PS3 to its most basic 480p graphics mode so you'll be able to see enough to choose RGB SCART, component, HDMI or whatever from here.
gave it a go, but holding down the PS button did nothing, apart from switch it on initially.
I tried it 2 ways, once with the PS3 off, pressed the PS button (which switced it on and continued to hold it waiting for 2 beeps), got nothing.
Then with the PS3 already on, I held it for more than 5 seconds and still got nothing.
none of that reset stuff worked for me, but just now I've managed to make it work on this TV...in the most ridiculous way possible.
I took it downstairs, switched it on, and then went through the steps to get to the display settings auto setup part...I wrote down how many times I had to press each button (X, 4 left, 9 down X, X, X, X) which gets to the auto display setup. Then I brought it back upstairs and did it all again blind.
If thats what it takes to get it working every time then Sony are a pack of absolute retards.
You can try to set the tv to 60Hz, commonly used with game consoles these days, also the tv is only capable of 720p display output so set ps3 to that on your larger screen 1st, as you are already de-scaling the picture resolution from console as tv is 1366x768 maximum display resolution not 1980x1080p as your larger monitor is capable of. If all that fails get on the line to samsung customer support 1300# and they will talk you through setup :)
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
