just been out for my first drive on them and they are great, more comfortable then stock 15 y/o suspension and holds nice and flat round corners!!)
what dampening settings are u useing for street. mine are currently set on 4 all round. I think i am going to put this up to 8
gtstcoupe, another question for you or anyone else that has superstreets...
With the dampening adjustment, if u get lost as to what setting ur at, how the hell do u know how to get it back to say setting 1(soft) or 16 (Hard)... the dial just likes to keep on clicking.. :laugh:
Ahh you will find that 16 stage is not 16 clicks there is about 20 clicks of travel in it and it just stops when you get to the end of it.
If lose count, just go bak to softest untillit stops and then count back or vise versa.
Ohh i use 3 clicks btw
Cheers :laugh:
mine are aus spec.. currently set at 10 clicks back from hrdest setting and still a softer , more confrotable ride then stock, with next to no body roll and not bump or harsh at all....
10 / 10 here for teins..
Based on street use though, not sure how they would be on the track under more extreme conditions!.....
ok while your talking about it
which way is which - is it like the old HA's where full clockwise is stiff and anti clockwise soft?
just picked up a car with the aus specs and need to loosen the rear
Well i got monoflex but yes its anti clockwise to soften and clockwise to harden. i can't see why they would swap one model around :)
Cheers
Camden
They don't just keep clicking guys. turn them anti clockwise until they stop. you are at zero. Count up from there.
The manual on the aus model super streets does state that it's 16 clicks, to go any further is doing potential damage (or words to that effect).
Id say they would be referring to people "forcing" them to click any further. But there are more clicks than 16. As i think has already been stated its around 20.
No wasnt say i dont belive you, but , if it wasnt ment to go only so far you would think it would just stop, but what your saying does make sense.
I tested out the click wheel on one shock before i put them in the car and thats when i discovered it went more than 16 clicks, and i have them at 3 clicks from softest in the car. :D,BHdave,i will definatly keep that in mind. :sick: ,Be interesting tho to seeif jap spec are differnt to aus, as i know aus has different valveing?
Teins FTW :D
Thanks Mate
Edited by gtstcoupe
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
