hey all.
my skyline is pinging around 2000rpm threw to about 3000rpm dose any one have any idea what could cause this i have changed plugs. running v power. put some octane boost in. im thinking possable the timeing as put it on comp an the timin angle is 5%.7
thanks
martin
https://www.sau.com.au/forums/topic/225862-skyline-pinging/
i just wounderd if any one had experinced the same or similer prob.its hard to describe exactley wat its doin inless u drive it.
would you recomend anywere or no anyone in newcastle area??
thanks for all the advice.
martin
https://www.sau.com.au/forums/topic/225862-skyline-pinging/#findComment-3980039
15 degrees is what the timing should be at.
If its at 5 degrees, deff get it checked out by a mechanic who looks after imports.
Dont go to nissan as they will charge you thru the roof and probably wont know what to do since they dont work on skylines everyday like other work shops..
Or you could do it yourself and perhaps borrow a timing gun from someone to check.
Edited by siddr20
https://www.sau.com.au/forums/topic/225862-skyline-pinging/#findComment-3984784
My car is totally stock save for a nismo rear muffler and I have my boost solenoid on a switch. If I run 7psi down low it also pings at about 3000RPM.
Higher octane fuel helps, I've also heard that a better exhaust will improve cylinder scavenging and might help this problem.. planning to do it anyway so will see if it helps.
Already checked ignition timing, changed fuel filter, and fitted 1 heat range colder plugs and makes no difference.
https://www.sau.com.au/forums/topic/225862-skyline-pinging/#findComment-3987501
Always used 98RON, I wouldn't use anything less either. It is definitely happier on 100RON.
Timing is 15 degrees, plugs are NGK BK6RE something somethign.. i think the standard heat range is 5 so it's 1 colder. Standard 1.1mm gap.
I have used consult software to try richening the mixture or retarding the timing, and in both cases when I get it to the point where pinging stops the car is running like a dog. So I just leave the boost switch at its normal value so I'm only running 5psi in the midrange and 7psi up top (which it is fine with).
I am thinking that a new exhaust/cat will provide less restriction and hopefully push my load points a bit further which will make the ECU richen things up slightly. I think "taking it somewhere" will only produce one of two outcomes - they will retard my timing further making it run like a dog or recommend a PFC which is a logical (but expensive) step. Really the only thing I haven't tried is replacing the fuel pump, and I don't think that's the problem because the pinging is worst in the midrange.
https://www.sau.com.au/forums/topic/225862-skyline-pinging/#findComment-3990066
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
