From memory.
- Remove front grill.
- You will see 2 or 3 plastic screws/clips, remove them.
- Remove side indicators, and remove another set of screws
- 2 or more screws underneath the front intercooler opening.
- 1 more screw on both side of the car where the front bar bolts onto the side fenders (wheel arch).
- Jack up the car and remove both both brake duct (should be 6 screws each side)
- Then remove a bunch of screws along the front lip
I believe thats should be it. You can check the 32GTR service manual for a better illustration.
Can someone please tell me how to remove the front bumper on a 32 gtr? I'm trying to replace my intercooler. I've searched everywhere but could not find a guide.
Any help would be appreciated.
Thanks
If you were in Perth I'd give you a hand. Good luck! I helpedmy mates swap a URAS front bar and a stock bar off 2 R34s... URAS bar has 2 bolts and 2 screws... The stock bar was help in by some stupid amount, had a HUGE pile of bolts at the end of the day, and then we lost them all...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
