guys i think you should note that it is most probably an "IMPUL N1" not the NISSAN limited edition N1 where only 228 rolled off the nissan floor. 32impul, i have no doubts that yours is the impul spec n1 but the rest of the general public (including me) wouldnt know anything about these special edition cars put together by another tuning house. i think you should say that your parts are "impul n1 turbos" etc to save any confusion between your car and the nissan factory N1 we all know about. ive seen some pics of your car and it is very different from the nissan n1. please tell us more about it! it looks very tidy!
  • Replies 61
The IMPUL N1 does not come with air-con, ABS originally, It doesn't have whole for rear speaker and rear rain ripper. The bumper for front, side and rear is original plastic item. Gearbox is pull type.
If I remember correctly, A/R 42, M24 is the markings on stock GTR turbos.
That's what those turbos have stamped on them.
update: Here's an old thread you might want to read.
http://www.skylinesaustralia.com/forums/sh...&threadid=11066
These are standard turbos and they're exactly the same as yours:
Merli - The ones in that link actually have much larger compressor wheels than R32Impul's
There's more to turbo's than the A/R ratios it also has a lot to do with the wheel diameter.
I will measure the wheel size when I get to work tomorrow.
Does anyone know the standard compressor wheel size of GTR or N1 turbos?
Doc./
Yes, you are correct that there is more to turbos than just A/R Ratios :)
but no, I did notice that the turbos from the old thread had larger compressor wheels. Well spotted. It is of no consequence anyway, NISMO N1 turbos have the following markings on the compressor housing:
Compressor Housing: A/R .60 M24
Exhaust Housing: .64 696-2 T695
I'm 99% sure of the info above, but as always, I might be wrong... If I am, than I apologise, but I just don't want someone to purchase "N1 turbos" and then find out they're just stock turbos.
If you think I'm wrong, please feel free to provide evidence in the contrary.
The Turbo's have the same housings as stock turbos but the wheels look slightly larger, hard to tell without verniers. They are in excellent condition and have only done a genuine 37000 km... see the car and you'll no for sure they're genuine.
Impul 32 is definately 50 rwkw more powerfull than another 32 with same boost that was dynoed on the same dyno on the same day. The ECU has been opened and it is standard. Therefore we believed that this power could only come from the turbos.
Doc.
Sh!t I never new that was a geniune Impul gtr. I spoke to him once, and he told me it was a vspec 2, but it didn't have brembros, it had factory nissan calipers sprayed in red. and I'm pretty sure it had air con as well. I did notice the Impul raear bar and the impul instrument cluster. Also the rear GTR badge was mounted on the left side (instead of on the right) which I thought was weird.
Hope we are talking about the car White R32 with the plates IMPUL, stock wheels
hi man, that time I also didn't notice my car is a N1. the reason that the Brembros not in the car is my perious owner (JSV-Alan) he think that the 16" wheel has better handling on the track and looks better than the 17", so he took away the brembros and replace with the nissan item.
Impul is currently under stage 2 mod in BMT, the reborn impul will be build base no the track racing spec. I am quite sick of drag!! and I feel just a bit of waste to turn the N1 impul to drag car.....!!
don't you think?
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
