Cheers Thomas,
Not a lot of room thats for sure.
Yep, just waiting for some valve shims and other stuff to come in from Japan ordered through nissan Blacktown.
Can't wait to get her on the road!!
Should be the longer drive on yours, get back to us on what you find. My engine was out of an R33 GTR by the engine number as it was changed before it came to Aus I'm sure.
I was going to go a fresh set of stock pistons, rings, bearings originally, or just the forged standard size pistons to freshen up till I found the scores.
Bore and hone cost $350 (sort of a favour) thats why I got away with keeping costs down, head skimed, cleaned etc $90. All the rest, done myself.
The hardest thing is not spending more money on crap you didn't put in your goal, budget. It really can snowball, gotta draw the line somewhere lol.
Edited by GTRsean
  • Replies 109
Cheers Thomas,
Hey Sean..
Hopefully I find out about that drive sometime this week.
Definately know where your coming from about drawing the line.. Like I said same situation as you were in a few weeks ago.. Yet to open her and decide what needs to be done all pending on condition..
Cheers Tomek
coming along nicely! :P cant wait to start on mine..
as for the budget thing here's my story.. was going to put the n1 motor i bought straight in.. took 5 months to get here so i started buying bits and pieces.
then when the motor arrived i was told to pull it down to inspect, which moved me towards a full rebuild, lucky as there are some small scores up and down the bores on most cylinders, so a rebuild was a must.
hopefully will finish up under 10k haha
Cheers Andrew.
Wish I had an N1 block lol, nah, not for my application :(
Scores in the bores?, how deep are they?. It would be nice if they disappeared with a light hone would be nice, but I guess you will take it out to 86.5?
  • 3 weeks later...
Nearly there!
match ported manifolds while they were out.
New shims to do valve clearances.
Bolting up as much as I can before it goes back in.
Craved is nearly finished. Loving his work.
Nope. I'm happy with what I put in it. I'll kick myself hard later, but N1 pumps go ok.
Still have to find out what housing I have here, that I was going to put the billet gears in and use in the engine. It's not an N1 pump so I didn't use it due to being unsure of what I had. Still don't know, no one knows.
The one on the left. No idea?????
Have I lost anyone lol.
Tomoz morning is the plan.
The other thing I did the other day was setup and adjust the inline throttle setup. Completed that in accordance with the manual, and it's pretty easy after you read it like 5 times lol. Nice and smooth and all good.
There was a couple o little things this arvo to get done before she goes in, like fit the balancer and torque to 350,000 foot pounds lol. And fish out a washer I dropped down the front cover GRRRRRRRRR! It's out phew.
Got covers off Craved today :P:P .
The guys who spotted the covers in the shed were blown away lol, no complaints here lol.
Engine bays is a bit neater.
Just befor balancer was fitted.
Edited by GTRsean
Thanks Brad!
What a long day. Tired and got a headache.
Had to improvise with no chain for the engine crane this morning, (mate borrowed it a month ago).
Twin plate clutch was the first thing to go on this morning.
Cracked the s#%ts with crawling under the bloody thing later in the day. :D
Had a mate help me but had not much experience, so I'll be finishing up tomorrow.
To do tomorrow:
Bolt up gbox x member
Fit center tailshaft bearing mount
Fit a couple of belts and fan
CAS sensor
wiring
pipework
front suspension top nuts
gear shifter
Fill up oil, and do up sump plug!
Fill front diff.
Fill power steering
Coolant and bleed
Crank over, then start!
Bed in engine. ;)
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
