complete rb25det
rb25 head with lifters and valves still untouched$450
rb25 block $450
power steering pump $50
A/C compressor $100
rocket covers both $50
camshafts intake and exhaust $100
intake manifold comes with injectors, anything that bolts onto it $150
exhaust manifold stock $50
cross over pipe with stock bov $50
flywheel still in good condition can give clutch as well for
free still in pretty good condition $100
timing covers and coil pack covers $80
throttle body $50
ecu $100
alternator $ 60
wiring loom $ 120
o2 sensor $ 30
engine mount brackets no rubber $30? for both
stock dump pipe $10
r32 turbo $100 if u want u can see what its like before i take it off and put the r33 one on
PLEASE LET ME KNOW IF IM ASKING FOR TOO MUCH CAUSE I REALLY DONT KNOW OF HOW MUCH EVERYTHING WOULD GO FOR, THAT WAS JUST AT STARTING PRICE FROM WHAT I SAW ON OTHER PEOPLES POSTS SO JUST OFFER, IM EASY WITH EVERYTHING.
basically anything u want from an rb25 engine,
the only thing i kept was the turbo,crankangle sensor and coilpacks
theres more that i have missed so just ask and ill tell you if i have it or not
i bought this motor with the intention of building it up again to put into my car but i had
a little accident so need funds to fix up my bodywork.
thank you for your time
can sell as whole for a cheaper price if u want.would prefer it this way saves the hassle.
Location; melbourne south east
contact; pm or 0412-219-552 email is the [email protected]
https://www.sau.com.au/forums/topic/226315-complete-rb25-motor/
is it all in pieces? series 1 or 2?
anyting missing?
cheers
umm i think its a series 1.
i took the turbo, coilpacks and cas.
if i can get the wiring loom ill chuck that in.
the only thing i can think of that is missing is prbly some pipes, here and there, and the brackets that hold the cams down which i am currently trying to look for now. somewhere in the workshop
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
