  • Replies 120
Originally posted by adam 32
how would you bring boost on earlier with a more agressive timing curve? surely it will still flow the same amount of exhaust gas therefore the turbo will always spooll at 4K?
Ask steve @ sst. I wont be going down the drags till I have the wolf3d in and tuned. Dont see the point in going until the car's setup right, plus my tyres are hitting about 12 months in age, although not completely lacking in tread I'm sure they wont be as good as new ones but I'll still give them a try. I think my stock ecu is ****ed, in the mornings (cold or not) the car searches up and down, sometimes to the point of stalling but doesnt quite and then finally settles on about 1500rpm till it warms up and then sits around 650rpm, sometimes the car idle is lumpy too, but I think thats spark plug related.
Originally posted by rob77
I think my stock ecu is ****ed, in the mornings (cold or not) the car searches up and down, sometimes to the point of stalling but doesnt quite and then finally settles on about 1500rpm till it warms up and then sits around 650rpm.
Mine does that. Grant told me what it was. Can't remember now, something is a little out of calibration. Computers not f#cked.
Mine does the hunting thing too on cold startup every now and then.. I find a tap of right foot seems to sort it out pronto tho..
Robbie i dont think you will reduce your lag marginally with an exhaust manifold change
Your kidding yourself, the ex housing is too big and the efficiancy range is way off what boost your stock internals can handle
Im guessing 100rpm better spoolup with the manifold. maybe 100 rpm more with the tuned computer but even that is optimistic
down the drags you poofs
Originally posted by caminperth
Any ideas when I can use those tickets you gave me rev?
At "The Clink" in freo, this friday night. Event starts at 10pm goes to 1am or so. I may or may not be presiding over part of the nights event, subject to my wife being there. :)
The stock internals are pretty strong, the problem is the RB25 compression is a tad too high to start with.
Rob's got a 'cadbury turbo', a bar and a half of full boost.....
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
