do you need to get it for the como or for something else?
what was the reason it was $1500? things need fixing? not many places will risk their license if the car is obviously unroadworthy. I had to get a wrc and while i was there a guy comes in, in a beat up como and expected to just hand over money and get a cert without an inspection. the mech flatly refused his money and told him to go somewhere else.
I couldnt understand your last sentence..ha
lol nah my commodore aint beat up or nuthing
There is a little bit needed for the RWC. But the guy i took it to was too picky said a couple other mechanic when I told them that they wanted to charge me $1500.
Just wanted to know if there is someone out there who will let go all the minor things.
