1993 R33 Skyline GTS25t
Basic specs
2.5L DOHC intercooled turbo
5 speed manual
4 wheel steering (HICAS)
'Wine Red'
Factory option side skirts and extended front bar
Factory 16" alloys
Rare factory electric sunroof
155,000km
Mods
Full turbo-back 3" exhaust – nice note, not too loud
K&N pod filter (can supply factory airbox if required)
Turbosmart wastegate bleed currently set to 11psi
5-puck brass button clutch (can supply full-face if required)
2750lb pressure plate (standard is 1600lb)
Darkest legal tint (T35)
Autometer boost guage
Turbo timer
Platinum spark plugs
Full immobiliser and alarm system with remote start and remote central locking (installed by Chris Rogers… plug plug :) )
Stereo
Pioneer DEH-P6050 head unit
Alpine splits in the front
Factory upgrade Bose carbon fibre rear speakers
US Audio 504E amp (4x50W)
Fusion 15" dual voice coil sub in custom 85L ported box
Asking price: $23,000
It goes well, it handles and it stops. It has run a best ET of 14.18 sec and a best terminal of 102.4mph. The car is tricky to launch with the button clutch but once off the line, it goes very well and there is no way the clutch will slip. With a decent launch it would be an easy 13 sec car, backed up by a private-road run with a S6 RX7 :)
I've serviced it every 7,500km with top quality oils, replaced filters etc. Will sell with 6 months' rego and Mines ECU (on its way from Japan as I type). It has a current safety certificate.
This has been an absolutely fantastic car, but it has come time to upgrade and I'm in a position to do so. Mmmm, GTR... :D
I'm in Ipswich/Brisbane on weekends and in Toowoomba during the week. If you're a serious buyer, I can be contacted on 0417 761 243, or by email at [email protected]. The nature of my work means that I'm sometimes out of mobile phone range, so if you can't get me just leave a message with your contact details and I'll get back to you.
PICS
https://www.sau.com.au/forums/topic/22680-fs-r33-skyline-gts25t-se-qld/
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
