Hey guys, was wondering who out there with an RB30-25/26 engine is running the factory wiring and ECU?
More interested in the ECU, as you can run the factory wiring, get an adapter plug and run an aftermarket ECU :-),
I have a bare RB25 R33 engine, no wiring loom and my 260z has a RB30 engine, wiring loom and chipped ECU in it currently - even at this point, all my current engine wiring has to go to make way for the RB25 head, but not sure about which way to go!!!
I slapped a turbo on the side of the RB30 engine and then chipped the ECU, however, wasnt overly happy with the way it turned it, A/F ratio's werent quite right, was a bit doey, didnt make as much power as I would have thought (170rwkw on 14psi with t3/t4) and throttle was very weird,
Basically looking to save myself the R&D, of buying an R33 wiring harness, trying to chip an R32 ECU (if it will even plug into the R33 loom) playing around on the Dyno and then just going out and buying an Autronic anyway,
I have read through that RB30DET Faq and it says the stock wiring and ECU can certainly be used, but maybe better only as an interim measure? I cant see any reason why an R33 RB25DET wiring harness and ECU wouldnt work properly with the RB30DET engine, but any first hand experience would be greatly appreciated!!!
https://www.sau.com.au/forums/topic/226856-stock-wiring-harness-and-ecu/
If you use the wiring/ecu to suit the head you're using, then that is the easiest way.
I'm using a my factory ecu (remapped) to run my 25/30 but I'm using an RB25DE head out of an R32 so it was mucho easy.
My RB25DE didnt come with the wiring loom - so would have to grab one,
Just curious how I would tell which R33 RB25DE wiring loom to get?
There is a series 1 and series 2 R33 RB25DE right?
Then there would obiviously be a harness that suits the N/A and Turbo engines respectively,
My RB25DE engine/head is from a 1993/4 R33 (I think) but is there anyway I can make sure I purchase the correct wiring loom? or does it really matter?
I assume the turbo harness has stuff like a knock sensor, whereas the N/A loom wouldnt,
Also - I would probably want to use RB25DET injectors and RB25DET turbo ECU
Really know fk all about 33 stuff, sorry dude.
Also unless you have someone near you that can remap 33 ecu's, I wouldn't be using one.
The reason I kept mine was because I could get it remapped which was needed by the way. The 30 maxxed out the standard airflow meter pretty quickly and I needed a remap to run the z32 afm, figured while I was there I might aswell chuck some bigger injectors in too (don't know how close the stockers were to maxxing out).
Yeah been reading and it looks as if the R33 cant be re-mapped and I wouldnt be able to use the R32 ECU as I am keeping the VCT,
Oh, Autronic's are expensive!!!
But if I used the R33 turbo ECU, injectors, AFM and loom and kept the boost low, like 8psi - the ECU should be able to run that shouldnt it? I would guesstimate that to be around the 180-200rwkw with the RB30DET engine running the stock R33 RB25 turbo - or is the stock R33 turbo ECU incapable of this?
From what I've seen the R33 ecu's tend to hit R&R sooner than the R32's.
e.g. When we built my 30 I had it running on the stock ecu, any more than 10% throttle or 3000rpm and it was into R&R. It was also maxing the airflow meter at about 6000rpm (afm maxes, ecu can't read more air so stops throwing in more fuel). Was running 10psi through RB25 turbo.
I had a remap chip from a groupbuy on here that got me round for a couple of months (had no afm cut) while I collected injectors, afm and saved for the tune.
We kind of under estimated the engine as we didn't expect it to max things quite so quickly..
What do you mean by into R&R?
Well I guess no matter which way you look at it the stock ECU isnt probably going to be a long term option stock with the RB30 bottom end, even if you do go with a stock turbo, injectors and AFM,
Guess a more straight foward option would be to use the RB25DET harness, ECU and then plug in an APEXI or something like that!!!
the harness for the r33 rb25 is the same regardless if its n/a or turbo, series one or series 2, nissan was smart like that.
If you look at a n/a engine bay, certain plugs that are used only for the turbo application are still there but are just taped aside.
I have a complete loom for a rb25, pm if interested.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
