Hi Guys
I got some stuff done to my skyline during the week. FMIC, 3" Cat back zorst, High Flow Cat, 3" Dump pipe,Bigger fuel pump, Apexi air induction, Apexi Digital boost controller and then I got the Nistune to 0.9 bar of boost. I was reading in some old topics that people with same car (R34 gtt auto) same stuff done to there car and they were getting 173wrkw at stock boost. And at 0.9bar of boost I got 158wrkw. Is this the power you would expect from a R34 gtt auto?
Trent
https://www.sau.com.au/forums/topic/227476-power-for-skyline-r34-gtt-auto/
Yes the car was tuned yesturday by Hyperdrive. They used Nistune to remap the ecu.
They were saying that it was the first R34 there to use the software.
hmmmm..
doesn't sound right..
not 158
hey sell that car and buy mine. :whistling:
Edited by rice boy
Does sound a little low, though Hyperdrive do seem to have a reasonably accurate dyno (as in it tends to be lower than some) but that wouldn't be that much of a factor.
My manual R33 GTS25t managed 190rwkw with similar mods (though my boost curve isn't great).
Post up your dyno sheets and maybe we can figure it out.
Hi mate,
I have a 1998 nissan skyline gt-t auto sedan, mods are fmic, turbo back exhuast 3inch, greedy electronic boost controller, k&n pod filter. Car on 10.5psi made 189.5kw, and stock boost which was 8psi made 183.3kw. Mind you this is with std fuel pump and std comp. This is the safest level to boost a 34 running a stock ecu. As if you go past the 12psi mark they usually start to cut out thats how the std ecu's are designed. Your figures don't seem right, i would be expecting a little bit more power. Post the dyno sheet up if possible. Hope everything goes well
Cheers.
Edited by DRFT31
I would post a picture of the dyno run but last night when I was at a mates house, I was about to leave so I started the car to warm it up then and it was running for about a min then it just turned off. So I tryed to turn it back on but it wouldn't start, so I waited for about 15min came back the car started for about 30sec's this time and I couldn't get it started again so. wtf :) . So now the car is stuck at my mates house and I will need to take it back to Hyper Drive to fix it. O yeh and the Dyno Sheets are in the car so I can't get them.
Hi mate,
Cheers.
Where was the dyno done for yours, I'd be suspecting that your numbers are a fraction high.
I dont understand, I thought you lose around 30% of power from the fly through drivetrain in his case 158kw making thats 211hp at the fly making that around 150rwkw....
On my dyno sheet i got 270hp at the fly i dont have 270rwhp...
Edited by Dani Boi
It doesn't just depend on what mods you have bolted on, what about the condition of the engine?
And judging from what you said how the car wouldnt start properly before. I think your plugs might be fouled or ro0ted. Might be responsible for a proportion of the power loss? m2c.
34 GTt's are 206kw flywheel stock (take about 7 or 8 kw for auto so ~198kw) and i dont think you would lose that much to the wheels without any mods. so with those mods its definately low. Did u get ur car from ur mates yet ??
You don't lose a percentage, a drivetrain will sap a certain amount of power but that doesn't increase with power.
158rwkw does seem rather low. I made 183rwkw with a similar turbo on the same dyno.
If a tuner is giving you a dyno sheet reading flywheel horsepower yet it's a chassis dyno, it's just a guess. Ask for one at the wheels.
Edited by bubba
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
    • Short inlet runners cost quite a bit. Dulls off the off-boost torque, and delays boost onset, because arrival of boost is driven by gas flow is a product of the ability to flow air which is torque. This is the reason that the stock manifolds have longer runners. On a 3L, or bigger, you can usually accept the compromise of giving away some torque because the extra capacity gives you a little extra to waste. But on a smaller motor, there's not a lot there to start with. Example, I swapped RB20 out of my R32, 25NeoDET in its place. The "wall of torque" that I experienced afterwards made it all worthwhile. That's because I came from RB20 land where torque is not a thing. But I would not do anything, anything at all, to reduce the low/mid torque I have now, because I remember what it is like to not have it!
    • Really, low/midrange torque goes really bad?? I want decent acceleration, maybe I use a stock rb25det neo manifold?
