Hello guys,
i read a lot of "oppinions" about the "crank-collar-case" until now however i'm not sure about a few things.
I have a JUN oil pump and do i need to fit a crank collar on my RB25DET '95 (Series 1.5) engine or will the RB25DET
crank match the JUN Oil Pump perfectly ?.
As i heard only the "most" R32 GT-R RB's have problems, but didn't heared anything about the RB25DET ??.
The next thing, if i'm understanding right that the collar have bigger flats to run the oil pump, do you mean wider flats, or longer flats, or both ?
Thanks in advance for your help guys.
is that all rb25's? or just ealry model ones?
short answer: you will need a crank collar
longer answer: all rb30, rb25, and early model r32 rb26 cranks are narrow and need the collar, the later model r32gtrs, r33gtrs and r34gtrs have a wider "snout" and dont require the collar to fit a pump like the jun
Edited by R34GTFOUR
OK guys can you please help me to understand this, some are speaking that the flat surface isn't that wide as it should be.
Do you mean the width of the flat surface or the length of the flat surface or both?.
I need to know this to be able to explain it to my engine builder.
Check this:
Check this:
length...your engine builder doesn't know this??
send it to me.
If he didnt already know, cant be that experienced with RB's... make me wonder about other things like oil control etc
Sounds risky to me :D
yeah RB's are a bit more involved than a Holden Red motor.
Edited by DiRTgarage
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
