As some of the NSW guys will know, my car was broken into last weekend and pulled apart in an attempted theft. My thread about it is here: http://www.skylinesaustralia.com/forums/R3...en-t227047.html
I took a good look at it this morning again to try and work out what they're damaged, and I have a feeling that the steering column is boned as well. I've attached a couple of pictures to try and show the damage. You can see the left over pieces of the ignition barrel mounts. They popped the barrel itself right out from between the ends where the screw threads in. Then they've jammed something in through that circle on the column to free the column lock as well, I guess.
Is it possible to knock that back into shape? Or is a whole new column going to be needed. :) The whole thing is f**king upsetting. Thieves are absolute scum.
There's also an unaccounted for plug dangling out from the dash. I have no idea where it goes. Some of the clip has been broken off. Does it plug into the other end that I've taken a picture of? I think it might be for the light behind the clock on the dash, as it's not working.
All help is appreciated. Thanks.
No, no - I spoke to them about it and considered it, but it's going to work out a little cheaper sourcing the parts myself and doing the work rather than getting Nissan to sort it out. Plus I get to keep my no claims bonus this way.
sheesh they really were ammature thieves werent they, when my ute got done they used a slide hammer on the key barrell tumbler and then used a screw driver to turn the ignition itself. what a mess, they other idea would be to drop the key ignition all together and and get a race car setup with push button starter and ignition switches etc. see your local leccy, i dont think it would cost much to install a panel, also the next time a thief walks along and sees the car without an ignition hes more likley to walk away scratchin his head.
There's actually some merit in that idea!
Because there's this story about how a man was bashed and robbed on a train...
As he got off and went to the station master he said, "Next time I'm carrying heaps of money I'll get on the train while I'm already bleeding."
With Empathy,
Terry
i was thinkin wen im gettin me 34 ill get it with a immobiliser and set up a tazzor so ween the people trigger the immo he will recieve a nasty shock 200K volts hope he loses the use of his ass hole and has to shit in a bag for the rest of his life
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
