Item:180sx bonnet
Age:not sure
Condition:has thick high fill that needs to be taken off
Price:$100 ono
To Fit: (180SX)
Contact:Shell 0420872166
Comments:Minor surface rust, easy repair
Edited by D-Project
https://www.sau.com.au/forums/topic/227959-180sx-bonnet/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
