I have an R32GTST standard driver seat for sale. In very good condition.
It has been repadded around the ribs to add more support and can be made quite tight with the lumber support. Repadding was done by Master Auto Trim in Sydney.
I also have a cold air partition for the 32GTST. Taking offers.
I am in Sydney
Pics:
http://groups.msn.com/paul17maher/shoebox.msnw
Offers to PM please....
or you can email
[email protected]
https://www.sau.com.au/forums/topic/22803-r32-gtst-seat/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
