FOR SALE:
A set of injectors upgrade (x6) for GTR, will fit into any GTR engine and maybe GTST with abit mods. Flow 550cc /mins.
Asking price is 280$.
Turbosmart BOV type 3 Supersonic. With flange to fit into GTS-T.
Asking price is 220$.
Just give me a call on 0415210220 or email to [email protected]
https://www.sau.com.au/forums/topic/22825-injectors-bov-turbosmart-for-sale/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
