Ok so my r33 gtst is boosting at 11.6 psi... .8 bar and i dont have an aftermarket ecu, and i cant make the boost go any lower!! Mods: pod, cold air box, r34smic, 3" dump 3.5" cat back, and a turbosmart dual stage boost controller.
So am i right in thinking the problem lies with the boost controller? I heard they werent that great anyway... and theres no point in me having a dual stage when at the lowest setting its already over what i can run with no aftermarket ecu!
Anyone know where i can get a good cheap manual boost controller? and are they defectable?
Edited by Alex_r33s2gts25t
Have you installed it correctly? You're meant to be able to set exactly the boost you want. Double check you've got it facing the right direction and all the lines are right, oh, and that you've set the knobs correctly.
Turbotech (ebay) make a great & cheap manual controller.
from what i know a less restrictive exhaust can be causing your spike in boost. my mate with a 33gtst had great boost control while stock - after he put on his hks superdrager.. boost control turned to shit.
if ur not planning on going for big power just get a ebc and get the stock computer retuned - something safe 13psi'ish?? will take care of ur problem and will make it safe to run that higher boost for not that much of a cost.
hope this helps.
stef
Hey yeah all the lines are facing the right way and its installed correctly... the knobs are turned as far back as they can go for their lowest setting.... before i did the exhaust (had r34smic, and pod and cover installed) it was boosting at 10psi... i couldnt change it any lower... then with the exhaust now its 11.6psi wtf..
Then again, when the aftermarket boost gauge was telling me 10psi, the factory one was saying about 7-8psi...
i need to get it tuned... then they can test it and tell me wtf its boosting at :)
i need to get it tuned... then they can test it and tell me wtf its boosting at :D
If you're after correct problem diagnosis, shell out a few bucks, get an ECU remap and dynotune at the same time. The following guy is realistically priced and knows his stuff:
http://www.skylinesaustralia.com/forums/Re...no-t210097.html
If you do require a good manual boost controller, a Turbotech is the way to go. Make sure you have an accurate boost gauge before you start modifying boost levels. Don't rely on the factory one!
http://cgi.ebay.com.au/Turbotech-manual-tu...1QQcmdZViewItem
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
