hi all,
i've got an r32 gtst that i want to put an intercooler on
i've researched it a bit and have decided it will be one of two
- blitz lm (return flow style)
- trust/greddy type ls
my question is, will cutting the hole under the battery tray, as required for the greddy cooler be a defect
is it worth spending the extra money on the return flow style
also, i understand i would have to cut the reo to fit any fmic (is there a way around this?), if i'am defected for other reasons and have to go to regency will they spot the cut reo or can't you see it
cheers
https://www.sau.com.au/forums/topic/228802-intercooler-legalities/
if u cut and go to regency youre screwed.
+1 its just not worth the damn hassle. any good cooler worth its salt will fit into the stock vehicle. cost u more in the longrun if you get defected, and its not worth undermining the integrity of your vehicles structure... at least thats my 2c
Speak to Ryan at ISC or Mark at Exhaust Tech, they can probably fix you up with a nice cooler for your car which wont require cutting
-D
i have a 4inch thick cooler on the front of my 32 and it required very minor cutting to the reo bar, and it still passed regency. if you get a 3inch cooler it will fit no probs, plus cutting the hole under the battery is fine.
if the dudes at regency have a bad day, or his wife gf didnt blow him that night or woteva, and they see anything cut, you will cop the regency big black dildo with no vaseline.... not worth the headfux 4 a streeter. get a GTR...
dave your intercooler is massive!!
i guess the front bar dont fit over that motha!
Iv hade two diffrent bars on the car and both nedded to be cut, its a cheap china GTR DRAG COOLER 600x300x125mm which set me back $500 but im looking at getting a greddy or hks item soon.
so some people have got the greddy ls kit to fit without cutting the reo, or just trimming a little?
has any one been through regency with the hole under battery tray?
yeah my car passed with the cut whole, just make it neat and use some rubber edgeing around the hole so that it wont rub through your cooler pipe, and all will be sweet :D
Pretty much whats been said. My reo bar is cut and i passed regency earlier this week. I got lucky though. Im pretty sure there is a DIY tutorial on SAU
somewhere where someone has installed their cooler without cutting their reo bar at all. Do a search. I'd find it but i cbf XD
cutting a whole into the chassis is where youll be screwed but under the battery tray youll be sweet as. make it neat and youll have know drama's as its not major part of the car.
dont cut the reo bar, if you have to make mods to it just take it off that way you should be fine when it comes to regency time as you can just put it back on insted of looking for another reo bar :D
Edited by Import S13
From memory there should even be a outline for where the hole needs to be cut out on a 32, its where the GTR cooler pipe goes through, so it should be very easy if you use the right size hole saw :D
Edited by DSTROY
as long as you cut the hole under the battery tray is accurate you might not even have to bend any pipes! otherwise you can just use both the standard intercooler holes and run one pipe underneath the cooler
like nos man said, in my 33 i got my cooler piping going thru the standard holes and got a pipe running back underneath my cooler.
I just did my own return piping from the fmic to the stock holes from the smic. No cutting to chassis, reo bar, bodywork, nothing!
I agree that as long as you keep it neat and tidy, you will generally be okay.
:D
My cooler went in without any cutting of the reo, and i have a just jap kit! If you buy a greddy, it will most likely fit without much hassle or custom work.
No cutting Damo, but a bit of bending was required.
    • Order for the 2025 model R35 GT-R were accepted from 3rd March and 26th August the last order rolled off the production line at the Tochigi plant. Concerning the R35 GT-R replacement, current Nissan CEO Ivan Espinosa said "Nothing has been decided about the GT-R at this time, but we are well aware that everyone is waiting. The GT-R will evolve and reappear in the future. Please be patient until that day comes." Nissan has a lot of issues with management and finances so take Espinosa's words with a big grain of salt. From what discussions I've had and read about here in Japan, not a lot of people are confident about Nissan's future, let alone the next GT-R.
    • Thanks. We getting some parts along too so he will be solving the speed issue like next week so i will let you know what he came up with.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
