  • Replies 665
Posted Images
Just want to double check that everyones name on jumper is correct. This is the final list. Thanks!
Username Type Colour Size Name on jumper
Damo_r34 Hoodie Black S DAMO R34
Damo_r34 Hoodie Grey S DAMO R34
Damo_r34 Hoodie Black M
Rad32 Hoodie Black M RAD32
Rad32 Hoodie Navy M RAD32
Nene_rs4 Hoodie Black M NENE
Nene_rs4 Hoodie Black L BEN
Ryanrb25 Hoodie Grey L
Ryanrb25 Hoodie Black M
Heslo Hoodie Black L heslo
Heslo Hoodie Black L I have an RX7
Bunny33 Hoodie Black M Bunny
Jonnyboy09 Hoodie Black XL JONNY
vinnie32gts4 Hoodie Black M vinnie32GTS4
Dstroy Hoodie Black XL DSTROY
bezender Hoodie Black XL CARL
bezender Hoodie Black L
min_r32 Hoodie Black S
Gtr-r32 Hoodie Black XL GTR-32
Gtr-r32 Hoodie Grey XL GTR-32
typevu Hoodie Black M TYPEVU
love my 32 Hoodie Black XL ANTHONY
muirsky Hoodie Black M MUIRSKY
gi joe Hoodie Black M GI JOE
cronic Hoodie Black L Cronic... (with the dots)
cronic Hoodie Black L 32 Zilla
r32skyline93 hoodiet Black M GRAHAM_R32
hi2u Hoodie Black M
slammed32 Hoodie Black XL Slammed_32
inh3aven32 Hoodie Black S
inh3aven32 Hoodie Black L SCOTT
inh3aven32 Hoodie Black L InH3aven32
Fabs_32 Hoodie Black S
frankyp11 Hoodie Black L Franky
johnzey Hoodie Black L SNIPER
nightcrawler Hoodie Black XL Nightcrawler
sklyn Hoodie Black XXL Msquito
inline6 Hoodie Navy S
mrgtt Hoodie Black XL MRGTT
foxycleo8 Hoodie Black M
thomasino Hoodie Black L
lin33r Hoodie Grey M
260tech Hoodie Black S 260tech
fishpaste Hoodie Black XL Fishpaste~ (include the ~)
sled Hoodie Black XL SLED
vija Hoodie Navy M Matty
gtrkeit Hoodie Black M k1etz
jenkies Hoodie Black L JENKIES
TOTAL 48
Username Type Colour Size Name on Jumper
Damo_r34 Jacket Black S DAMO R34
Rad32 Jacket Navy M RAD32
DRD-00F Jacket Black M DRD-00F
DRD-00F Jacket Black L JAY
Bunny33 Jacket Black 6
Eddyfier Jacket Black L #3 Chris
Flick Jacket Black S FLICK
monkeyboy Jacket Black M
Dstroy Jacket Black XL DSTROY
min_r32 Jacket Navy S MIN_R32
Gtr-r32 Jacket Black XL GTR-32
Gtr-r32 Jacket grey XL GTR-32
jugz Jacket Black XL jugz
typevu Jacket Light Blue S MEL
love my 32 Jacket Black L SARA
musky Jacket Black M Musky
sambo33 Jacket Black M Sambo
imports13 Jacket Black XL Kye
imports13 Jacket Light Blue XXL Pinky
ruby Jacket Black L RUBY
ruby Jacket Black L RUBY'S GIRL
N-dawg Jacket Black XL NATHAN
r32skyline93 Jacket Royal L R32_SKYLNE
jack88 Jacket grey L
usmair Jacket Black M USM41R
Fabs_32 Jacket Black L Fabs
lukeenr34 Jacket Black XXL ENR34
krishy Jacket Black L KRISHY
sklyn Jacket Black L Sklyn
ontheranch Jacket Grey M
scottydoo Jacket Black M Scotty_r34
scottydoo Jacket Black M D2
lin33r Jacket Light Blue S
whatsisname Jacket Black L Whatsisname
sled Jacket Black 10 Daniel
fullyhyper Jacket Red S fullyhyper
madaz Jacket Blue XL Madaz
TOTAL 39
Mine are correct, except can the R in R34 please be a captial too?
scottydoo Jacket Black M Scotty_R34
Thanks :D
I'd like to say thanks for doin a great job of organising this too, quite easy to deal with even though you have lots of people to sort out.
So Cheers :P
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
