hey guys.
Currently i have a stock r32 gts-t that is running the standard turbo. However its nearly on its way out and it is screaming, i was told that the vg30 was a good upgrade (the ball bearing one). Just wanted to know if anyone else on sky aus has used this before in this car and if so what does it perform like and is it any good? Also after i buy the turbo i will also install a front mount to go with it.
any advice or help appreciated
thanks niran
https://www.sau.com.au/forums/topic/229046-turbo-change/
hey guys. yer i might try the rb25 turbo. but is there anything good about the vg30 ? is it bigger and is it any better?? and um thanks mate but i was thinking of getting a bigger one and getting rid the rb20 one.
thanks niran
https://www.sau.com.au/forums/topic/229046-turbo-change/#findComment-4027817
First up you need to tell us if you mind a little lag. If you don't then go for the vg housing with RB25 turbo. If you find one the owner will probably ask too much for it so your better off looking for a 2532hks or similar. For the money I'd go hks. Without knowing your goals how can we advise ? How much do you want to spend ?
https://www.sau.com.au/forums/topic/229046-turbo-change/#findComment-4028233
ok hey guys. yer true i could try that one. ok by lag how much lag would i be expecting?.. and um the price for the turbo he is a friend of mine, so he said he will sell it for $350.00 for the ball bearing one with the steal shafts. is that worth it?, it has no shaft play ither.
thanks for all the help guys let us know what you think
niran
https://www.sau.com.au/forums/topic/229046-turbo-change/#findComment-4028467
Im running a VG30/RB25 turbo on my 33.
Its a VG30 rear housing and wheel on an RB25 turbz, I find it is pretty responsive still, and it comes on boost harder than the stocker.
oh realy. i might look around for that see if any one has that for sale. thanks for that
https://www.sau.com.au/forums/topic/229046-turbo-change/#findComment-4028567
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
