Hey guys,
Just wanted to get an idea of what was more expensive brand new in Japan. Take for example a :
- Manual 6-Speed 350z 2003 Track. and
- Manual 6-Speed V35 350GT 2003 Premium
both optioned with 18" factory rims.
Any ideas?
Cheers
Hey guys,
Any ideas?
Cheers
From memory 350z base model started from $65k new, and the 350GT would've been around $38-40k? correct me if im wrong...
btw, the Z price would've been australian, and GT is Japanese price...
Edited by GEXer
hi mate,
Well according to the US, the v35 costs about USD5000 more
thats based on a cost base of 30-35K US, So the equivalent here would be 7-10k AUD here
if the v35 was sold here, I'd expect the preium to have gone for about 70k AUD.
hi mate,
Yes i've read that on G35driver forums also. That's why I was wondering what the price difference would be in Japan.
But then again the G35 wore an Infinity badge, which automatically inflates vehicle price I reckon.
I think from memory they were more expensive in Japan as well.
The V35 if you take 03/04 for example, "track"version, both cars were identically spec'd, with the V35 having more options, being a larger car, with two extra seats. Why would they charge less??
Both had 18's
Both had Brembo's,
Both had the same engine
Both had the same running gear
V35 was longer so more "material" costs
What you said there makes sense Bobby.
I'm trying to get a hold of sales brochures for the 2003 versions of the Z33 350Z and the V35 350GT in japan.. having no luck so far. Would be interesting to get a definitive answer I reckon.
Material costs have nothing to do with the end price.
Eg: Do you really think that the cost to build an MX-5 is that much more than a Mazda 6 because it has a soft top? It's because it sells an image.
It wouldnt suprise me if the Base Zed is a fair bit more than the Base V35... but when you start specking up... then you start paying for "luxury" "tax's"
I dont know which would be more expencive, but it wouldnt suprise me the (lack of) "logic" of pricing scales for the two vehicles.
Being a grey import a V35 will always be valued a lot less in the eye of the buyers. and that drives the prices down, plus the initial new prices of 350Z are set by official Nissan dealers with their dealer delivery charges etc, and that translate to the average used car prices by working of the average depreciation over time.
A V35 350Gt probably gonna cost more or less the same with the same year local 350Z with almost double the km. That means a local 350Z with the same year and same km with the 350GT will be more expensive.
But we're just trying to an idea on the sticker prices *new* from japan.. e.g. timewarp back to 2003 and I was a japanese guy looking at a brand new car, what was more expensive at that time?
It's more of a curiosity thing, i don't care what's actually more expensive, just that I heard from someone that the 350GT was more expensive to buy new.. just thought i'd try to confirm that rumour.
Here you go (prices from first official press releases):
Skyline Coupe (6MT Premium - Y3,560,000)
http://www.nissan-global.com/EN/NEWS/2003/.../030116-01.html
350Z (6MT "S" - Y3,300,000, "ST" - Y3,600,000)
http://www.nissan-global.com/EN/NEWS/2002/.../020730-01.html
I think the "ST" was the "Track" so from the press releases, the top 350Z was Y40,000 more expensive, but you could probably add a lot more options to the Skyline to make it more expensive overall. The "S" had the Brembos too which would make it a closer equivalent to the Skyline (a tad softer) therefore I would use that as the more accurate comparison, making the Skyline more expensive (as you would expect).
Anyway, the Skyline is far better value as a grey import (and I looove it sooo much).
Edited by MaXiMuS007
Great stuff mate!
Okay so going by today's exchange rate that is (103.90Y:$1AUD)...
Skyline Coupe (6MT Premium - $34263AUD)
350Z (6MT "S" - $31761AUD, "ST" - $34648AUD)
Or on historical rates (80.76Y:$1AUD at 01/07/2003)
Skyline Coupe (6MT Premium - $44081)
350Z (6MT "S" - $40861AUD, "ST" - $44576AUD)
That's awesome value, considering you can get a V35 for roughly 30-40% cheaper than the equivalent Z33 350Z today on the 2nd hand market.
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
