I have been having issues with my car going into R&R mode I installed a PFC recently and had it tuned (unigroup), now what I have noticed is two tings my car now has a hesitation/pause, almost light somethings cutting the power this comes every now and again I think its always been there but its only noticeable with the power FC (don't think its in the tune). My knock reading on the power FC will go as high as 112 but the engine light does NOT come on at all. I think this hesitation/pause has always been there, but possibly the tune has made the hesitation more noticeable. Its seems to only do it on light acceleration. And the knock reading wont go above 38 at any other time. I am thinking the fuel pump is on the way out???????? Also the engine light attached to the power fc knock system is set at 60 is there a way to check its on/set at 60. Any suggestions?????
https://www.sau.com.au/forums/topic/229196-strange-hesitationpause/
First up, I'd talk to Yavus about what he thinks about your hesitation, as he clearly would have noticed it.
What turbos have you got - surge maybe?
PFC's don't have RR.
112 knock is bad, don't do it.
Datalogit / power excel to check the knock flash setting.
Fuel pressure gauge should show a f.pump weakness.
Edited by GeeTR
I have std turbos, I know Power Fc don't have R&R it was doing it on my std computer it just wasn't noticeable (cant think of any other reason I was having R&R too coincidental) and sometimes it will have this hesitation and not read any knock ???? i would have thought Yahulz would have picked it up as well but they wouldn't do a power run on very light throttle and its intermittent, and as I said the power fc is not reading knock and showing me on the dash light as I have never seen the engine light come on. Dont have datalogit. yeah i should give him a call but i dont think its got anything to do with his tune its an unrelated problem but he is the man to see. its just miles away from where i live.
    • Oh please, when has anybody really been "done" when they say that? 😂
    • The part where you claim the car "is done" means you won't...
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
