Your last sentence is a bit confusing, but if you change your ride and by the sound of it you have coilovers, any height adjustment will generally require a alignment after.If you want people to help you with your questions type them properly.......
https://www.sau.com.au/forums/topic/229213-34-gt-toffset/#findComment-4031989
I think what he is trying to explain is everytime you lower the car, the wheels will start to camber in which allows for more aggresive wheel offsets to be used without any guard mods.
This is from personal experience - optimal offsets lowered approximately 340mm all round measured from center of wheel to guard.
18x8 +30; 18x9+30
18x8.5 +35/+30; 18x9.5 +38/+35
The above with 235 and 265 front and rear rubber respectively will require no rolling of guards. Fronts may have slight scrubbing on inner plastic guard on full lock if lowered excessively. Just quoting offset of wheels without reference to wheel width is useless.
https://www.sau.com.au/forums/topic/229213-34-gt-toffset/#findComment-4032104
factory GTT wheels are 17x7.5 +40 all round.
Well unless the 1000's pairs of factory GTT rims i have seen are are duds, i swear they are +35.even on my 180sx has Gtt wheels which say +35 on the inside of them.But anyway
https://www.sau.com.au/forums/topic/229213-34-gt-toffset/#findComment-4058477
Post a pic of the wheel and we'll tell u if they are indeed the GTT wheels you are refering to.
https://www.sau.com.au/forums/topic/229213-34-gt-toffset/#findComment-4058506
    • Out of curiosity, how do officials determine what the OEM ride height and suspension specs are? Do they have a book of truth? I'd think that would be quite obscure knowledge for random JDM cars.
    • This is the check list they sign off on. This implies that adjustable coilovers of the type we're referring to are not a "Variable Ride Height" system. This very much is in the ethos of "I can change the height while moving/while parked without pulling wheels off the car and mechanically doing so"
    • Just an update  ... Put the cat back on no issues with the car running wise ... maybe alittle longer to spoil up the turbo. Still running rich but waiting for my tuner to come back into town to retify the situation. WOT runs fine with the cat.
    • Hi,    Where does everyone buy their stock GTR R32 replacement parts from in Japan preferably? I usually order alot from RHD Japan but sometimes they dont have what I need. Whats the best website for parts in Japan ... as I live in Hong Kong so best ordering from there.    Thanks
    • My post contains the actual truth. Clause 3.2 b.
