*points and screams at wogboy* its a NISMO BAR hahahaha
nismo nismo nismo....
Howie go get that catalogue :(
OK, here it is... the nismo rims (lmgt4's?) look awesome with that kit.
Okay, well there's nismo part numbers.. should I grab them too next time i'm there? I feel like it's deja vu again.. i've had this conversation before on sau. :(
Hey, all I'm saying is that I see a NISSAN brochure with NISMO tuning parts on the back page. :( Where's the other NISMO body kit?
If my kit had NISMO stamped on it like my other NISMO parts I'd totally agree, but it doesn't and I can't :(
Don't get me wrong, you maybe totally correct, this is just my opinion ;)
By the way, the front bar and skirts that I brought came off FIL-034, the rear bar I got off another SAU member.
Yup.. nismo nismo.. that's what the nissan dealer told me when they bought me a nismo altia front bar. but this is a nissan factory option as in fitted in the nissan production line and not at nismo.. if that makes sense.. ok.. i've confused myself now.. lol.. good luck with the sale.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
