Hi guys I need some help in how to remove the rear tail light on a R33 skyline, I undid all the bolts ( I think) and I was trying to remove the plastic facere on the front but cant remove it.
As I have undid all the bolts the rear light should just full out right???
or do I have to remove the rear bumperand there might be some bolt under there to remove the taillight.
all this to drain out some water.........
HELP
https://www.sau.com.au/forums/topic/22995-water/
yeah, as silverskyline said the centre skyline section is best removed! it has 4 nuts the can be removed from behind the boot latch, then it is push real hard (and even) to remove the light section which is held in with the black silicon (sikaflex) as used on windows. then only real way to get the water out would be to drain it out the clip for the indicator or reversing lights!!
be very hard to get the blinker section off, same issue with the front of the headights!!
then you'll have to clean up the light and body of the black silicon (takes a while) may need to get some from super cheap to replace this!! just make sure you dont get any on the body and light!!! will need thinners etc to clean this off, which is not good for your paint!!
good luck with it!!
https://www.sau.com.au/forums/topic/22995-water/#findComment-496316
nizmokid: dont hold me responsible should this not work or screw up yr lights in anyway...
just advice man and hv seen ppl do it work a treat too...
they took power drills...found the smallest f*ckin drill head on earth and just drilled a tiny little hole near the bottom. All water drained out, never had a flood inside again and never had the inside condense again..
my 2c...
https://www.sau.com.au/forums/topic/22995-water/#findComment-504796
yeah cause to get the face plate of the lights off you have to takwe the lights out as the screws are between the covewr and the body of the car!!
so yeah, remove the whole unit to remove that plate, but dont think it will get much easier to get the indicator plate off. good luck with it though
https://www.sau.com.au/forums/topic/22995-water/#findComment-504813
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
