Item: HKS 256 Intake/ HKS 264 Exhaust Camshafts
Age: Purchased a few months ago and were in car for a few dyno runs and a bit of driving around town
Condition: As new, not a mark on them
Price: $800 delivered
To Fit: RB25 Series 1 or Series 2 (Retains the VCT on the intake side)
Contact: Just PM on here or reply to the topic
Comments: Cost me over $900, Slide sells them for $480ish delivered and hoping to get most of my money back :) My cars setup for some reason didn’t like the cams, it ran fine with them but we just couldn’t get the power we wanted. We narrowed it down to probably being a valve train issue or something so I bought valve springs due to planning to rip the head off. At the moment I can’t afford to do that so selling the lot and maybe ill attempt it again one day if I can be bothered.
Item: Performance Valve Springs
Age: Purchased a month ago
Condition: Brand new, never taken out of box
Price: $290 Delivered
To Fit: RB25
Comments: Purchased these through work at Autobarn for my staff price of $290, was going to go through with it but now im not. Ill do them for the same priced but delivered. If i can't sell them i'll just hang onto them incase i do the cams in the future again.
Item: Standard AFM and plug
Age: 1996 Model Skyline
Condition: Perfect working condition
Price: $100
To Fit: RB25
Comments: I run a microtech ECU so no need for this.
Item: Standard R33 GTST RB25 ECU (Manual)
Price: $100
To Fit: RB25
Item: Standard R33 GTST Bov
Price: $50
To Fit: RB25
Comments: No need for this.
Item: Standard R33 GTST Plenum (Has been sand blasted to as new finish)
Condition: As new, had it sand blasted inside and out so ready to be polished or what ever else you may need it for
Price: $80
To Fit: RB25
Feel free to ask any questions you want or if you want more pics.
Thanks guys.
Hey sorry guys, valve spring and HKS cams are no longer for sale. Im going to attempt it one last time by taking the head off and installing them. F***ing cars, so over them lol.
Plenum, ECU and AFM still for sale though if any one is interested.
Ok change of plans for the final time. After much discussion with my tuner, we are going to rebuild the head but he doesn't want to use the HKS cams so i am giving up on them and going to try a set of Poncams and see if they work. They are back up for sale if any one is still interested or will do a straight swap for Poncams (the HKS ones are dearer so you would be getting a better deal).
Sorry for mucking people around.
Thanks
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
