hey guys. Im in Canada and im wondering if anyone will email me their PFC D-jetro tune.
My mods are.
SS exhaust manifold
SS dump pipe
apexi down pipe
3,5 inche exhaust
HKS GT-RS twins turbees
intercooler
750 cc injectors
timing gears (not tampered with)
turbo XS BOVs
anything will help if its a djetro tune at least I can compare mine to any of yours.
PM me if yah want to help me out.
https://www.sau.com.au/forums/topic/230396-d-jetro-tune-help-a-guy-out/
Thats the problem. The tuner where im from cannot get to it at the moment. Too buisy because of other builds.
any other Base Maps i could use just so it isnt running so rich. my o2 sensors are pinned at idle as far as i know thats not right.
my dilemma is that where i live in canada there arnt many tuners that know the djetro . So I was wondering if you would email me your tune with your list of mods. If you dont want to I understand but all I can do is ask.
cheers
Sorry Phil, I am a cheque book modifier :P which means I have no idea what tune my D-Jetro has. But from what I found when looking through the fuel mapping, there wasn't much changed at all. Someone here should be able to help you though.
cheers
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
