Vehicle 1989 NISSAN SKYLINE HR32 GTS-T
Price $8,000
Kilometres 129,681
Body 2 door 4 seat COUPE
Colour grey
Interior Colour dark brown
Transmission auto
Drive type Rear
Engine 6 cylinder Petrol Turbo 2.0L (1998cc)
Reg Plate AR06LI
Reg Expiry OCT-2008
Road Worthy Certificate No
Vehicle ID 5877195
Brief Comments Great car no problems runs very well auto
Comments
The car has a front strut brace, boost controler boost up more than standered, cat back exhaust cd player, sunroof , just had a service new fuel filter,spark plugs,diff and trans fluid,and coolant and brake fluid no more work needed to car everthink is good runs really well never had anyproblems.
car is in sydney northern beaches call me on 0421259933 jason
https://www.sau.com.au/forums/topic/230413-r32-gtst-8000/
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
