  • Replies 45
Im not going to pay outrageous prices for local ones, but ive seen some decent cars sold from the sunday times last sunday. Skipper rippoff mitsubshi sells r33 1993 skylines for $17999, and i passed on a bunky one in canning vale for $14000, so anywhere in that ball park is were i wanna start. No NOS kits sorry!
paul
Why would I buy a private sale for $17000, if i can get a dealer one for $17999 with a warranty? Unless this car had some sort of modifications? What is the car details, man, turbo?
What defines a serious buyer, i just sold my silvia so i guess you could call me a definate buyer cause i need a car to drive to work.
paul
also what are the km on the clock, what colour?
also the $14000 one only had a front nudge on the vehicle which required a new bumper support, thats why it was priced accordingly.
paul
I would not consider $17,999 for a 93 manual , turbo Line expensive , especially with a warranty. If you want a real cheap one ,import one and take the risk.
Cheers
Ken
paul
The number of 'decent' skylines on the market is rather low. Once you have driven a good one you will know what I mean.There are many 'good lookers' with mechanical issues. I'd say ignor the low kms tags and just evalutate the mechanicals for themselves. After all this is what low kms is supposed to indicate.
If you can find a 'good' R33 for $17,999 then you are laughing. Most around are not 'good'. Expect upwards of $22k for something decent, that sort of budget is realistic. More for a 95' in good nik or a series 2.
Geez,
$22+ for a 1993 - 1995 car. I just sold my silvia i imported two years ago for a complete loss, cause thats all they are worth.
Consider
1992 silvia NA, auto
Remus 2.5" exhaust, twin tips
Apexi Air filter
New tyres
Apexi extractors
Strut braces etc etc
I bought this car a year ago for $10000, i sold him last week for $6500, it had done 140000km.
But $22000+ for a ten year old car is getting up there, i could be looking at 1998 wrx's and stuff for that kinda money.
paul
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
