My bunky, Ford Meteor, has to last me until the banks get their act together and finance me! In the mean time I want to get a few things ixed on the bunky. The main thing I'm stuck with is, my driver's side window is broken (the lever that holds the glass in place) who would I contact to fix it? I knwo this sounds like a stupid question but I've asked several people, and no one knows!!
https://www.sau.com.au/forums/topic/231729-window-fixing/
Just call around some wreckers, I reckon you could get a whole working door for $50-$100... paint probably won't be the same, but its quick and easy & cheap :wave:
but then it won't be the gherkin Tris?
it'll be like....the Gherkin with the tomato door :(
https://www.sau.com.au/forums/topic/231729-window-fixing/#findComment-4072409
k so this probably wont help that much but most of the time with wonders like the gerkin best bet is a little diy action and a visits to your local wreckers
ive fixed afew window winders (mostly on mates comos) and most of the time a little elbow grease can fix it
https://www.sau.com.au/forums/topic/231729-window-fixing/#findComment-4075236
whats actually wrong with it? the lever is missing? or it doesnt wind up and down?
If the levers missing just get one from a wrecker easy as.
If it wont wind up and down then get the window mech from the wreckers.
Take off the door trim theres like 3 bolts? or so that hold it in place with the glass in a channel, take the mek out replace it with the new one, reseat the glass, done.
Its really not a difficult process, if you can get someone on here to help you out, better half of 2 hours.
https://www.sau.com.au/forums/topic/231729-window-fixing/#findComment-4076185
Spark plug in the fuel tank??
Take it to a mechanic, we do shit like that more often then you'd think. Us mechanics are pretty useful!!
SPark plug? wtf? lol I'm talking about the window!!!
Yea... its not hard. You're like playing with cars. DIY Mel :(
If not... I have a sledge hammer you can borrow :D
yes plskthanks
https://www.sau.com.au/forums/topic/231729-window-fixing/#findComment-4076492
all you need is someone with a little bit of mechanical knowledge to fix the window regulator. Its not exactly brain surgery. I pretty sure anyone could do it. :D
umm no the lever is snapped not stuck
1. the lever is snapped
2. we masde it so it can't wind up and down so that teh glass doesn't smash
3. obviously I've taken off the door trim, how else would I know the lever has snapped??
Ok so you guys reckon go to the wreckers and get a new regulator yeah??
https://www.sau.com.au/forums/topic/231729-window-fixing/#findComment-4077905
No longer need help with this! Thanks everyone for your ideas I got some really good quotes from RAC Auto Service Centre's if anyone has the same problems and you don't have to be a member.
Btw in the crash, the pen still held the window in place!! :P *Props to Bushman Mechanics*
https://www.sau.com.au/forums/topic/231729-window-fixing/#findComment-4094889
On this window topic... Does anyone know of a place that buffs scratches out of windows? places like O'Brian etc don't do it anymore because it thins the glass and affects the structure of the car.. but i just want the driver's and passenger's door windows done.
https://www.sau.com.au/forums/topic/231729-window-fixing/#findComment-4095109
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
