I found out (searched) that a good way to check faulty coilpack is using multimeter and the reading should be around 0.6 and 0.9 but that's for a RB20DET. Is the reading the same for R33 with RB25DET either with or without ignitors.
Attached is a picture of a Series2 coilpack (hopefully). Three terminals. Which terminals should i use to test?
I used 1&2 and got 1.0 and sometimes a 1.1 on the same coilpack. Is that good or bad?
Edited by teng
https://www.sau.com.au/forums/topic/231736-another-coilpack-question/
It seems my coilpack harness isn't spared as well. It's in horrible condition. As soon as i remove the connectors, bits of plastics falls off from inside the connectors. Time to get a new one i guess.
Pretty sure standard should read 1.1-1.3 Andrew
What exactly is the problem your having and have to diagnosed it back to the ignition system???
Looking at that plug you wouldn't be getting a great connection which will/can cause problems so i would change that ASAP and check all your others :D
Problem now is misfiring on idle. According to the workshop, it's connected to my coilpack as it hasn't been changed since 1996. I'm the 2nd owner so the first owner didn't bother to change anything i guess. lol Mileage is over 250k atm.
hi there im new here and this is a bit off topic im sorry. I have an a31 cefiro, has anyone of does anyone know if you can wire in the r32 ignitor into the cefiro harness to be used in wasted spark set up? i cant seem to find any diagrams for the ecu side of both ignitors as the cefiro one is ruined and corroded.. any help would be great thanks.
i had horrible misfiring from my coils and the loom was in really bad shape, my solution was to make up a completely new loom from the ignitor and solder the wire straight to the plugs pins then i cleaned the coil contacts and taped them up.
the tape only lasts 5000-10000ks so next time i plan to use some good quality heat shrink or i might try silicone.
it works well, i don't see the point in wasting 500-600 for spitfires sure i agree that it will give you a better spark but meh its a 20 year old $8k r32 why bother.
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
    • Hey guys,  Way back when (about 15yrs plus), I picked up a beautiful set of Tein 'Super Racing Spec Circuit Master RE' coilovers from Russman. I have legit never fitted them to my car, as it was garaged indefinitely while i bought a house Yada Yada. They look brand new! Anyway its time to pick up where I left off, and have started doing some khanacross and am booked in for a hill climb next month. The car has some hard af Nismo shocks in ATM, which has me wanting to upgrade again, and now I am left wondering if it's worth having these teins rebuilt? I think they where an ok shock back then, but how do they compare to what's on the market now?  Shockworks/mca are 2800+, and I am sure they are great. But if I can have these rebuilt and be better than, say, a set of bc's for around the cost of bc's, I would be happy with the performance v cost trade off.  If they are considered outdated and rubbish these days, so be it, I'll put them on the shelf and be happy to look at the pretty green colour while I save for the SW/MCA option. Grateful for your thoughts on the matter, and suggestions on who could do the rebuild if it's a worthwhile pursuit.  cheers, Rowdy.
