Hi, did a quick search but didn't turn up with much. I know Splitfires are the way to go if your coil packs are playing up, as genuine items are dear, but if you could purchase a new set of OEM nissan coils for simular dollars to Splitfires, which is best? Can u re-gap your plugs much the same if you were to replace with either new OEM or Splitfires?
Interested in changing mine on a '93 R32 GTR
Thanks in advance
https://www.sau.com.au/forums/topic/231739-splitfires-or-new-oem-coil-packs/
Put it this way, if you could get oem for the price of splitfires there would be a line of people waiting for you to get them some as well.
:D exactly.
The only real reason everyone gets after market coils is because of the ridiculous price for OEM items.
My OEM coils lasted well over 16+years until they started to break down :woot:
So, in performance terms there is no advantage other than pricing to go for Splitfires?
BTW, seen a set of new OEM coil packs advertised for $660AUD delivered. Yes, dearer than Splitfires but not by that much, and you know they will last!
:O exactly.
My OEM coils lasted well over 16+years until they started to break down :sick:
Hey, thanks mate. Interesting but they are compairing their new coils to 'old' nissan items. Wonder if any difference compaired to a new set of OEM coil packs?
Try Kudos http://www.skylinesaustralia.com/forums/in...howtopic=228296 he has awesome prices and service.
the new Australian developed Superspark coilpacks have been proven to make a 14KW gain over standard coilpacks on an RB25 motor.
which of course we can get you a set :whistling:
Testing on the Splitfires by UAS for Autosalon magazine showed NO gain in performance over standard coils.
Just make sure you get GENUINE Splitfires!
There are two versions out there, both look pretty similar.
One splitfire is equivalent to Super Spark Stuff and is priced accordingly. (not saying they're bad, you just pay for what you get).
The other is from "LynxCorp" the only (REGISTERED) Splitfire Coil Distributor in Australia. They sell GENUINE ones.
They're not too bad from memory (price wise). Look 'em up.
Cheers,
MaTT
Edited by ORACLe__
looks like it will take some convincing before super sparks are taken seriously.
I will have a discussion with Super Spark and Competition Tuning and Performance and do up another independent test run and report the findings.
I have read of a few instances of splitfires being bad, either out of the box, or within a short life span, so don't think I am being negative against one or the other. I just believe that the test of the superspark coils in that magazine was bogus. If the stock coils were breaking down, then it stands to reason that installing new units picked up power that was lost.. but I would have liked to have seen the difference between stock oem good coils and aftermarket. It was as if they installed a known bad set of coils to inflate the test results, and thats bad form.
If my oem coils start breaking down when the car gets tuned next (which could be very possible as they are siliconed up atm), I will be looking around at the options, splitfire, superspark and jjr. Decision will be based on 3rd hand information as always, but will be influenced by reliability, price, and availability.
Splitfire are a known quantity, with a few exceptions. JJR are cheap, with a very small installed user base, but not having negative yet. Superspark are an unknown for the same price as splitfire. We (customers) have to be given a positive reason to purchase, especially to move away from something that is recommended, as evidenced by the many posts people (fanboys) make when anything ignition related pops up and you get random post about 'just buy a set of splitfires'.
James.
^ if superspark were priced more reasonably i'd definately consider them but at the same/similar price as splitfires, i know which set ill buy.
edit: i just checked out kudos sale thread, theres none for s2 r33 and r34 anywya..
looks like i have to get splitfires definately.
Edited by dori32
we also sell super sparks and they will be available for series 2 soon.
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
