CRD Dyno day - DATE CHANGED - Now Oct 12th 2003
  • Replies 240
ok then moanie..........
hmmm welll we r going to be there pretty much all day so........
what is it ?? 2 in the first hr then 1 every hr after that..............
:( tehehee half a case..........
hey all, sorry for the late notice, but im gonna have to pull out. i'm taking the saturday off work for a ns.com cruise, and i cant get the sunday off work too..
so one spot has opened up...
have a good one and make sure u post up the results!!!
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
