hi guys, this is my first thread here, because im a new member to this community :( ,
but i was wondering if anyone knew where to source the racing spoiler that is on the Pennzoil R34 Touring Car, I have an image that i found on google:
sorry it may be a bit big, but i was wondering if anywhere did this spoiler because i think it would look good on my R34 gtt when i get it?
Cheers ! :wave:
https://www.sau.com.au/forums/topic/232013-racing-spoiler-for-a-r34gtt/
oh, so there would be no where to locate that spoiler type/style even if it where a replica, i just dont no, there is something about it that i like, and i think it would go well with the R34GTT project im going for very soon, i think it would be a big eye catcher and poker :worship:
yeah a definate eye catcher and defect catcher im sure you will stand out in the crowd with that indeed.
if you do end up doing it ,id really like to see pics, maybe try the Top Secret GT Wing, its huge but a little more subtle.
cheers,
David
cheers,
David
hey
thanks for that, you mean something like this type of spoiler...
well at the moment im just looking around for some decent aero kits, i have looked at, do luck, top secret, blitz and the top fav atm c-west, but i am still looking for other kits
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
