I have a random issue and im not sure if its a problem or not.
When i lose traction, launch hard or even just corner fast my rear end bounces around. Is this more likely to be;
worn out stock suspension
or
Crappy Tyres
?? I dont know if this is normal and other people have this as well, i always assumed spinning tyres would be nice and smooth lol :worship:
any help is much appreciated :P
https://www.sau.com.au/forums/topic/232047-bumpy-rear/
Sounds like axle tramp then.
I know of a few people that have had this problem and most of them due to the rear cradle bushes I believe.
Anyhow once they bought 'Pineapples' the axle tramp went away.
This does not mean that it will be the bushes but generally these bushes get old and are a main factor. It could also be rooted shocks, do you have a minispool? Lowered springs on standard shocks?
https://www.sau.com.au/forums/topic/232047-bumpy-rear/#findComment-4073724
I would start off with the pineapple bushes as they are not too expensive and do help with traction a fair bit.
These bushes are normally cracked and worn on the older jap cars
Edited by bluey33
https://www.sau.com.au/forums/topic/232047-bumpy-rear/#findComment-4076375
This bushes are normally cracked and worn on the older jap cars
thanks for the advice mate :)
will order some from work
I did have a look at the rear suspension and the driver side shockie had the erm...you know the rubber accordion type thing that keeps dust from getting in ?? yeh that was all dry and broken and had been wedged into the strut, pulled all that out. Will get some pineapples and maybe get some coilovers from there.
again, THANKS HEAPS !!! :D
https://www.sau.com.au/forums/topic/232047-bumpy-rear/#findComment-4076382
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
