Step one - Admit you have a problem.
Ok. I have a loud exhaust - 3.5 catback is not helping - Yes it has a mid muffler and rated a 93Db
Step two - Options
Apexi Active Tail Silencer - This works by a spring and seal which is pushed out via exhaust pressure, it fits into the exhaust like a normal cannon silencer and is dynoed at 16% all over power loss, which is acceptable for street use. It dropped sound overall by about 20% (no idea in db ratings)
Pros - Fairly cheap $200 in comparison to other options, Easy to remove.
Cons - Pain in the ass to actually be bothered removing, Abit of a eyesore, noticable to the police, noticable loss to HP/KW
Varex Exhaust cannon - Adjustable butteryfly valve which recirculates air through an external muffler to minimise sound, Sound drop is huge. I was hoping to weld it in after the cat as my catback is a N1 Mega Kakimoto with a very unique sound. What do people think about this possable?
Pros - Easy to work, Best at silencing.
Cons - Has to replace my current cannon which I wish to prevent, If replaces cannon you can see the butterfly, Exhaust size to large for biggest avaliable inlet they currently make, Will look tiny next to the 4.5" outlet cannon I have now.
Apexi Flange fitted Exhaust control valve - Worked via a manual wire which fires a butterfly valve to fully close, this would be pre drilled with 10mm holes to minimise airflow backup yet muffel sound (small holes is how a silencer works)
Pros - Easy to fit, Unsightly, Decent silencing, From what ive seen may be able to be hooked up to a motor/cog setup.
Cons - Controlled via big clunky cable and setup, may not be easy to trigger
Bigger, better mid muffler/hotdog - Currently the hotdog I have takes up almost the whole cat back its about 1m long so another hotdog would have to be revamped.
Pros - Cheapest.. Easier?
Cons - Chop up my nice SS system and will weld in some ugly mild steel crap.
So.. You've got the info, what do you feel is the best option? Do you think some of the ideas can be done and be sucessful>?
https://www.sau.com.au/forums/topic/232984-tone-down-exhaust/
It all depends on how much you want to spend... If you're a tightass like me, you'll go the cheapest way which will still leave you will the same power figures
It's all physics. Sound travels as a block, if you break up the block, you quieten the sound. When I was at apprentice training, a guy in my class had a silvia and the exhaust was too loud. All we did was drill 4 holes near the end of the exhaust tip and placed really long split pins so they formed an X across the exhaust tip...
without a dB meter we don't know exact numbers, however the exhaust note was obviously quieter and there was no performance loss whatsoever
If you don't wanna start replacing exhaust components, this is a much easier and cheaper alternative...
1. Hotdog = useless. Countless people have tried them and they dont do shit.
Just get TWO decent sized mufflers, and thats all you'll need.
You'll still have that niec RB note, without that attention drawing drone and noise about town
93dB is not a loud exhaust by the way :D
Hey Nathaniel
prsonally i would go for a Varex muffler, i was going to use one on my car but never got round to doing it
i will be using one on the WRX though
but in your case because you dont wanna butcher up your current exhaust
i would go for something like the apexi style valve
simply because
1. it works
2. you dont have to cut anything
3. im pretty sure you can find and electronic version
Thanks guys.
Clutch in is what im current doing, Idle is still loud and Ill be gone if I get RBT'd
Resonators and Hotdogs - Same things?
93db is the rating, due to its age I doubt its close any more.
The Varex is good but they dont make a 3.5 entry which will be a bottle neck with power. Im thinking Apexi device thanks Anth.
Thanks for the help.
Mufflers to much sound loss.. I think I just want to much - Dont we all
Edited by DECIM8
The Apexi sounds good. You dont need to cut up a flash exhaust system and is easy to open up when you want. (also simple to remove)
I find that in my 33 (3" turbo-back, split dump/front, HKS Silent Power) is louder at idle, so keping the revs constant around 3200rpm its silent.
Its a funny one, i dont know about others with the same exhaust, but the higher the revs the quieter it gets.
hey Nath
dunno y you would wanna change the exhaust. sounds great how it is! but i dunno if this will help with your pipe sizing but check this exhaust out
http://xforce.com.au/cars/view_car/29
hope you find wat u want m8.
Jaye
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
