Since spending a small fortune collecting parts ive now decided what I am and arent using.
Everything is in good working order photos will go up latter
Weaver 4 stage Dry sump pump. Apparently rebuilt before I purchased. Has been stripped down and inspected by westend after I received it. Was given the all good but Im not using it.
Comes with a few -12 fittings as well $450
RB26 Sump, has been modified to suit a dry sump. Pan has been cut and shortened, side wings cut off and plated, 3 -12 fittings welded into the side and internal baffles etc all welded in
I have made another with an extra baffle etc so using this instead $500
Bracket to suit a 5stage peterson pump. Also fits the above weaver pretty well. I made it from steel as a prototype but now machining up a replica from billet so the steel one wont be used. Nothing wrong with it I just wanted a billet one instead. $150
Will put up more latter with photos
Edited by Risking
https://www.sau.com.au/forums/topic/233304-dry-sump-rb26-parts/
  • 1 year later...
Hi, I am planning to put a petersom 5 stage ( roller bearings ) dry sump to a RB26 track engine. Very interested in your left overs. would like to go further either buying your prototypes. please call/sms me on 0439 818008 or 0433 878 905 to follow up.please get some photos. email [email protected]
cheers
Alex
  • 7 months later...
Very old thread but is that Weaver pump still around? Has it been used since that original post was put up?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
