Well, see here. Got meself this nice beaut black box
somthink call'd prowfek Bee spec eye eye
anyone willing to install it for me?
got to take out the Hybrid dual stage ebc, and install the ProfecB spec-II
havent got much $ atm, on dsp but no payment until Feb 09
could supply petrol money, subway lunch and drink? smoke?
Morphett Vale, into the Stagea. Not a big job, brand new profecb to replace the current ebc (good for 180kw but not 210kw)
help would be appreciated, hurt myself today simply changing the k&n pod to an Apex pod. knees are stuffed.
so best for me to watch help and clap.
does the profec need a road run or two to set up? got adelaide hills 1min away, quiet area
cheers.
brendan
home dad so anytime really
https://www.sau.com.au/forums/topic/233408-help-an-olboy-out/
Id say save ya pennies for a little bit and bring it down to Michael and I at Aussie dyno n Tune on a saturday, we'll install it and set it all up on the dyno and get the boost real stable. We did craigR33's not too long ago and he seemed very happy with the results.
EDIT:
If im not too busy ill come up and install and set it up on the road as best as i can...pm if you get stuck.
Edited by Ryanrb25
That reminds me. I gotta find someone with an AWD dyno.
Gotta get my box done next week (fingers crossed) and then fit the SAFC2 and SITC then tuned.
Tangles, if you get real stuck, give me a call and I might be able to give you a hand. My house settlement has taken a stumble, so I might not be moving in this weekend ... free time.
cheers all
getting the o-ring replaced in the attessa system from shaun at boostwerx, waiting on that from japan
he can set it up on the dyno for the last tune, just thought it be good to get it in pre-tune with a little road setup
:P
EDIT:
hey ryan hav u got time 2 run mine on the rollers satdee, need the air/fuel ratio's cheked out on the pfc, seems 2 be running 2 rich, i was the 1 that roked up cupla satdees ago when u were doing craigs car i was in the wine red 33 with white wheels
thanks Dan
funneh how I did something right lol
got pretty dark but good ol torch under the dash to wire up to 12v ignition and ground
getting thru the firewall took me ages lol.
hits 1.1 bar boost but then goes "woosh woosh woosh" as it drops and gains .2bar continually
got to sort that out, tryed with a hills run last night.. all in good time
pretty much thats it. all mods done
got to sell the Hybrid dual ebc for $100 and a k&n pod filter with z32 adapter for $50
:D
damn she goes fine
Ryan, when can I come see you at aussie dyno, for awd tune (fpr/safc/sitc touchup/ebc setup), and to use 2x spring clamps (to clamp each spring tight an inch, pull out circlip and drop one notch, put circlip back in Bilsteins, release clamps and seat properly) at each 4 corners.
cheers
:rolleyes:
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
