  • Replies 518
ive got his cd, taxed it from video hits people, he actually isnt that bad... he is rather diverse which is good.. ive heard his concerts go off too... some tunes like black and gold but then other funkier ones yo
i thought he was going to be shithouse, but i was suprised
want a copy schneggles
hopefully he wont do farken 10 outfit changes like west did
i got 2, always someone in need... could sell hbr life tix to find park and gv and shit lol
hopefully GV is good this year last year it was rubbish, year before it was best fest of the year
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
